Y17DTI astra van no power
Results 1 to 6 of 6
Thread: Y17DTI astra van no power
    Feb 2010
    Hi guys, I,ve got a 2003 astra van with a y17dti engine, it runs but will not go above 70 on the motorway and generally lacks power. All this occurred after a small accident, the air bag did not deploy, I checked and cleared the DTC on the ecu and have run the vehicle for a week and still no error codes show, can any one help as to what the problem is?
    Mar 2009
    WAKEFIELD
    Astra mk4 Corsa b
    Re: Y17DTI astra van no power
    Try cleaning air mass meter mine used to do it
    Feb 2010
    Thread Starter
    Quote Originally Posted by astra16vcdti View Post
    I Know this sounds a bit thick but is this the unit after the airbox?
  5. Remove Advertisements
    Feb 2010
    Thread Starter
    Tried cleaning the MAF still the same and someone suggested try running witthout the MAF connected that just turned on the MIL. any way through up the expected DTC on the ecu so still clueless as to whats going on any one got any bright ideas
  7. #5
    Feb 2010
    Thread Starter
    fixed it! turns out the turbo was shagged, replaced it and now runs fine.
  8. #6
    Mar 2009
    WAKEFIELD
    Astra mk4 Corsa b
    Glad u got it sorted at last
