hi, just put a x16xe engine from my corsa sport into an a reg nova & its runs for 2 secs then cuts out. I believe its because i havent yet put the transponder for the chipped key into the nova yet. Anyone know how to wire this into the nova? Plz help.
Red wire to battery 12v
black wire to ignition live supply
Brown straight to chassis/earth
brown/blue to your ECU warning light (brown/yellow choke wire)
blue/black to large rectangular plug for immobiliser signal
blue/red goes to the blue red wire at speed senderplug on gearbox.
hi, thanks for reply. That really helps. Where is the retangular plug for immobiliser signal? Also iv put a gearbox in which is a cable operated speedo so what would i do about that? Thanks again.
the rectangular plug is comming off the ecu side. the blue/black wire comming from the transponder has to be joined to the blue/black wire comming out of the retangular plug it has the wires that were used to wire in the engine. you will need to get a speed sender its for the ecu speed signal. to fit the speed sender u unscrew your speedo cable from the gearbox then screw the speed sender onto the gear box and then screw your speedo cable onto the speed sender. i think you can get 1 off a 1.2i fuel injected nova. the speed sender has 3 wires comming from it 1 is an earth 1 is a live and the other goes to the rectanguar plug i forget which colour is wich but i will find out
thanks mate, you've been a great help. been puzzled for a while now.
