is there anyone who have with succes used this idlevalve with DTA S60pro?
And what settings did you use?
Rgds
Patrick
Rgds
Patrick
not s60 but dta p8pro idle was as oem with the standard icv![]()
Is that the VW/Audi ICV? Might be worth trying to find someone using it on a megasquirt forum or something.![]()
Iīm about to connect one for getting stable idle.
as for my question,, i got a couple of those at home already.
thought iīd give it a try.
i was using the 20x14 map. i'm still looking for it
Leesturbo: thank you very very much, itīs very useful.
and by the way,, it wasnīt '512' valves i had. i had '516'
Anybody knows the difference?
Probably the amount the valve is open at rest I would have thought.
"Before you judge a man, walk a mile in his shoes. That way, if you decide you don't like him, you're a mile away from him with his shoes".
Nova SRi 1.6 16v TBs / DTA E48 1/4@14.8s
Phazer,, yes i had that idea too.
and there are an adjust screw under a little lid.
Yes there is, it's a pain to get the epoxy resin off though![]()
Tried the settings above.
itīs not 100% accurate with my settings as i got a newer software, or did you have an older ems Leesturbo?
Anyhow, it didnīt work.
as i fiddled around with the settings, the only reaction i had was REALLY low idle,like 450rpm.
the valve anyhow at itīs resting point is a little bit open(i guess itīs 'starting' air)
And when rotating a little bit it closes, then it starts open again(still rotating at the same direction)
I guess the only thing that happened when i was fiddeling was that i got it to close.
Todays testing is to get the epoxi resin away and adjust it to closed at rest.
anyone tested this?
and anyone tested DTA with ....516 and got it to work?
and one more question,, is it possible to make the connection wrong?
like positive on negative?
Been adjusting a bit again today.
Modified the valve so it can never close.
left it in ~1200rpm hardware adjust. unplugged from electric with engine running.
later on i connected it, and how the FFFF can the idle get lower?
and lambda wenīt down to 0.75, with no correctiontable for lambda filled in, all numers are 0 zero zit nada...
itīs like an hidden adjusttable that activates.
yes my ems was older to your s series
are you using the map 20x14 table ? or even have that facility?
it goes lean because the valve let air in
you have to balance that but i forgot how it was a long time ago
i will try and get a copy of my old idle 20x14 map
Yes it lets air in,, but i got a mapcontrolled fuel.
and.. why does it get richer as the valve canīt close?
are you using any other compensation tables?
basically i just learnt what settings did what over time "playing and learning"
http://dtaforum.psycode.com/
these setting does keep the valve closed at cranking, i changed to an unmodified one.
The Hertz were a thing that had to be tested, when having 24hz as leesturboīs settings the valve rattled really annoying, and i got really strange openings and closings of the valve.
and i have to use the PWM map, only PID loops as i had at first doesnīt work with this valves.
80% in the map keeps it fully closed.
And 100% fully open.
And when using PWM map the 'target rpm' doesnīt work either, As you 'hardmap' the valve to be open certain amount at different rpmīs.
Should be interesting tomorrow when i start the engine again.
Iīm having guests at my house this evening so i canīt have exhaust fumes in whole house *lol*
Yes,, i had to go deeper,, placed my laptop in my enginecompartment and wired a button to crank the engine so i could look at the valve in idlecontroller at the same time.
this is how i came up with the values in the post before this one.
and my experiences of that forum is quite bad actually.
Thereīs a certain guy that are all over the forum just saying how good he is to map, and leaves out the answerīs people are in need of.
And heīs bragging about his skills to map are so good that he doesnīt need any idlevalve.
Well,, everybodys engine isnīt like his engine i guess *lol*
weīll see tomorrow if lambda still messing with me.
the copy of my map with perfect working idle valve setting is hopefully at my mappers
i lost my copies from harddrive fails
i'll phone them monday if they are back for work after the holidays.
i seem to remember that 40% in the map was closed for my valve or a value you'd not expect i.e 0% closed 100% open it was more like 40 - 80 if you get me
i see an added table for your S series enrichment
so presumably that compensation table is to add fuel as the idle valve opens to keep afr's correct i would say ?
yes those setting may not have been my final map idle settings so please don't pay to much attention to them
but i'll deffo try get them as said
Finally!!
got it working.
the PID loops i found out yesterday worked the charm.
But!!
The trick is to NEVER let the Idlevalve to 'loose' the engine.
As i got light flywheel,clutch and crank my engine drops fast down to idle.
and the time it took for the valve to 'catch' the engine were to long.
Now i let the idlevalve adjust from 100rpm to 8000rpm
rpmband looks like this:
100
600
1000
2400
8000
Temp band looks almost the same.
-30
-10
0
10
20
85
90
95
120
- = means a ****load of more numbers i didnīt remember *lol*
to reach 1050rpm idle the values in PWM map were around 84.5%
lower rpm = more open valve,max value 88% down at 100rpm
Higher rpm all the way up to 8000rpm were 82%
Now the engine idleīs at 1050rpm and sounds like an std XE engine with sportsexhaust, really cool actually =)
and yeah.. lambda 1 also![]()
cool![]()
video![]()
