glow plug relay
Results 1 to 4 of 4
Thread: glow plug relay
    Nov 2004
    derby
    cav mk 2 convertab
    glow plug relay
    does any body know where the glow plug timer relay is on a vectra 2ltr diesal and also what does it do
    Feb 2008
    Waiwhetu, New Zealand
    96 Astra X17DTL
    Re: glow plug relay
    Quote Originally Posted by scampi View Post
    Had to make a couple of guesses about your vehicle - for a 1998 Vectra-B witha X20DTL engine found mention of a glow period control unit (looks like a relay) in what they call position 13 (a black one, second up on the right as you look at them) in the relay box "above the ABS control unit" near expansion tank. The name suggests that they control how long the glow plugs stay on...
    Nov 2004
    derby
    cav mk 2 convertab
    Thread Starter
    Re: glow plug relay
    thanks the problem with the car is it will noy keep running when its cold it will run for a couple of minutes and then die and not start again it does seem like the glow plugs are not on longenough
  5. Remove Advertisements
    Feb 2008
    96 Astra X17DTL
    Re: glow plug relay
    Sure hearing a lot of problems like this. If it runs for a few minutes then dies it may not be glow plug related. Maybe somebody else know more about it...
