Results 1 to 13 of 13
Thread: Problem With My Astra 2litre SRI (PLEASE HELP)
    Sep 2009
    Essex
    My astra has been running really well for along time now, but as i was using it the otherday, it started fine and everything, so i pulled away and it was also fine, then say about 5mins into my journey, i started to get abit of bogging down, and then engine light decided to come on.
    I then pulled over, toke the keys out of the ignition so ecu reset itself, then tried starting the car back up again. It didnt want to start again. Had to get it towed home.
    When i got in i check and changed some things:
    • Fuel Relays Clicking
    • Checked Fuel Pump & its priming
    • Fuel Filter Got changed
    • Fuel in fuel rail
    • Got spark and compression
    • All sensors have been checked and working fine
    • Fault codes checked and it says KNOCK1, KNOCK2, KNOCK3, KNOCK4, which is oviously due to fuel starvasion.
    • Injectors Not Pulsing
    Could the airflow meter be the problem as i no it doesnt come up on the fault codes reading??
    Car doesnt attemp to start, unless you spray carb cleaner/ easy start down the inlet manifold then it attemps to start.
    ANY IDEAS PLEASE, AS IVE BEEN WORKING ON THE CAR FOR COUPLE DAYS NOW WITH NO LUCK.
    Sep 2009
    Essex
    Re: Problem With My Astra 2litre SRI (PLEASE HELP)
    No-one has a single idea wat this could beee|????????
    Jun 2005
    Cracktown
    black 52' astra sxi
    I would try the coolant temperature sensor.
    Let me know what happens when you've changed it,
    Dave.
    astra 2002 sxi spare parts 07521382540 wheels, cd player cdr500, lights, seats, door cards, white dials, exhaust, suspension, breaks. spoiler. wiper motors, wiper arms.
    Sep 2009
    Essex
    Thanks mate for replying.
    What are your reasons for saying it might be the coolant temperature sensor?? Have you had this problem yourself then??
    Let me know as soon as you can. Thanks
    Quote Originally Posted by daveb948576 View Post
    Dave.
    Jun 2005
    Cracktown
    black 52' astra sxi
    Have you done a compression test? I'm a bit puzzled as to why it started to bog down and then stop never to start again, it didn't stop suddenly or jerk for a few miles it just bogged and stopped, have you taken the cambelt cover off to see if everything is still ligned up correctly?
    Jun 2005
    Cracktown
    black 52' astra sxi
    Have a go at checking for a live at the injectors, and make sure there earthed, the best way would be to put a 12 volt light bulb in the plug and turn the key.
    Jul 2003
    Skelmersdale, Lanc's
    A4 Avant sline,Corsa LET
    This could be the crank sensor. That can mess with the injector pulse. But you wouldn't have a spark. mmmmmmmmmm
    tech 2 it mate if you can.
    TOTAL VAUXHALL COVER CAR, SEPTEMBER 2008
    PS3 Online Tag:- VAUXBOOST
    Sep 2008
    Auckland, New Zealan
    Chevette XE, Calibra
    Very first thing I check on any engine that 'stopped' that has a belt, is if it's actualy turning the cam'. If it is, compression check is next in case it's slipped.
    [edit] See you've done that.
    Then start on the rest.
    BTW, while you've the plugs out for the comp' test, have a good look at them - they can give valuable clues.
    Jul 2003
    belfast northern ire
    a car beep beep
    i have the same problem with a c25xe in a calibra
    no injectors are fireing
    i even disconnected one off the injectors and got a mate to crank it over
    mean while i live wire 1 injector and opened and closed it manually
    it was firing on 1 cylinder
    it was as if the crank signal to the injectors was not working does any one know this part off the loom?
    its not my ecu tryed it in another car and it fired right up
    gonna replace the crank sensor (even tho the spark plugs are firing ) see what happens
    ok
    Jun 2005
    Cracktown
    black 52' astra sxi
    I think it's mor that likely to be the fuel pump relay but do as you wish
    May 2008
    flying past your GPS
    like escaped
    cam shaft sensor? [or crank]
    sounds like it was in limp mode and then ECU cut engine
    get a gunston's vaux fault reader
    loosing weight is the only modification for fellow fat bst'rds
    Jul 2003
    a car beep beep
    i tryed that unless its a broken wire to the fuel pump relay
    ok
    Jun 2005
    Cracktown
    black 52' astra sxi
    Where are you located?
    What's the engine code?
