C20 XE Removal probs!!
Results 1 to 9 of 9
Thread: C20 XE Removal probs!!
    Sep 2002
    Aberdeenshire Is: Mad as hell
    a Nissan!
    Cool C20 XE Removal probs!!
    Okay dudes, i just bought meeself another XE lump at a good price but the thing is i cant get the old bastid out.
    Everything is removed but i can get the shaft out from the gearbox, you know the one where you need a 12 spline bit.
    Is it possible to remove the engine with takin the box aswell?? I dont want to have to pull the shafts out then need to get box oil too.
    Any ideas much appreciated!!!
    Nissan Sunny - Eight Pioneer 6x9s , Kicker 15" Subwoofer, 2 400watt amps, Pioneer Headunit, it shakes!!
    Scotland
    Saab/Pug/Zaf
    yeah lift the lot out. you can also leave the smaller shaft in the box (take it out the hub obviously)
    it all comes out nicely, just needs 2 people to guide it out safely.
    Nov 2000
    Reading Berkshire
    Vectra GSi & GTE 16V
    I beleive you can use one of the ten mil bolts and screw that into the input shaft to withdraw it mate easier to leave the box in.
  5. Remove Advertisements
    Sep 2002
    a Nissan!
    Thread Starter
    yeah but you need to take the cap off first before you get to the threaded bit, so im to believe anyway????
  7. #5
    Nov 2000
    Reading Berkshire
    Yes but you dont lose gearbox oil by removing that
  8. #6
    Sep 2002
    a Nissan!
    Thread Starter
    But i havent got a 12splined bit to get the plastic cap off!!!! lol
  9. #7
    Nov 2000
    Reading Berkshire
    One word mate
    Halfords
  10. #8
    Sep 2001
    Sheffield
    Mk2 Astra Estate
    naa, you dont need no fancy tools, just remove all the bolts that hold the box tho the block and there a stabilizer that goes feom the driver side shaft the to block also, remove that, then its just a matter of prying the box and block apart with a crowbar or similar slowly, jusr do a bit at a time moving round the casing and it will pop out
  11. #9
    Sep 2002
    a Nissan!
    Thread Starter
    Spot on Jamie, cheers thats what i was waiting to hear!!!!
