BLown Gaskets
Results 1 to 2 of 2
Thread: BLown Gaskets
    Sep 2001
    E. London/Essex
    'DEAD 91 Cav GSi
    BLown Gaskets
    A friend of mine has just bought a Cav, shortly after found it was pi$$ing oil.
    spent 205 on a service incl. cam belt/rocker cover gasket.
    Still loosing oil. the guy who serviced it says it all happened because the engine breathing pipe was filled solid as a rock (took him ages to clear it) and the pressure build in the engine prolly blew the gaskets.
    IF this IS the case what gaskets is he looking at going? The head gasket is fine (im pretty sure of that) Id have thought the sump Gasket, (as strong as they are?) but surely driveability wouldve suffered, which it hasn't. car is an ecotec gls
    Any Gen on what to look into?
    Sounding the way XE should. WELL USED TO!!!
    Dec 2001
    No longer The Pheonix
    Gaskets to check would be sump,camshaft,crankshaft and rear main. If it's been blown out through blocked breathers it could be any of the gaskets/oil seals on the engine
    Please ensure all event queries are sent to me and i will reply in due course.....Thank you
