corsa gsi gear box
wot do i need 2 change 2 fit a corsa gsi gear box 2 my redtop engine i was thinkg
shafts, box, clutch,flywheel
ive got a f20 gear box on at the mo i just wnt my corsa 2 b quickr pulling off
thanks
Re: corsa gsi gear box
shafts are fine, just change inner CVs to suit the gearbox you will use. unsure on clutch and flywheel as im not that big on big blocks.
