Help please my c20let is smoking!
Results 1 to 7 of 7
Thread: Help please my c20let is smoking!
    Apr 2008
    tyne and wear
    corsa c z20leh + m32
    hi my c20let corsa is starting to smoke. the smoke is blue/white so im guessing its oil related. it hardly smokes when on idle but as soon as u rev it slightly it gets quite a bit worse. could this be the symptoms of a broken turbo?
    cheers
    Jun 2009
    Scotland (The Stix)
    Mk3 C20let Astravan
    Re: Help please my c20let is smoking!
    Yeah the seals on the turbo will be starting to go more than likely. Have you checked the tubo to see if theres play?
    MIGClub Member crombievts's Avatar
    Jun 2007
    Dingwall
    ph1 clio 172 track wep
    yep sounds like the seals r fooked. this thread might help you lol c20let kkk turbo
    Apr 2008
    tyne and wear
    hi no i havent checked to see if the turbo has play yet. if it does have play does this mean the seals are fooked?
    Apr 2008
    tyne and wear
    also can u replace the seals and if so how much are there and are they hard to replace?
    Jun 2007
    Dingwall
    im not sure on how hard it is to do or how much. do a search
    Banned
    Oct 2005
    ThickFord Shropshire
    a BMW again lol
    Quote Originally Posted by vinnys112 View Post
    hi my c20let corsa is starting to smoke. cheers
    I would phone the nhs quit smoking help line lmao
