picked up a c20ne to throw in our new track nova...
just wondered if its worth putting an seh cam and ecu on it?
www.wix.com/vxlgsi/zxr-750-r
SEH AFAIK was higher compression, different cams and different ECU.
If you can get hold of an SEH cam and ECU then why not?![]()
awsome.. time for a wanted advert!!
if your going to put cam and ecu from seh on it you will need to skin the head aswell other wise waste of time![]()
JSRacing ...10.7 astra mk2 ...10.4 tigra and they are both 8v turbos both on megasquirt :)
Drag cars don't have to be pretty they just have to go fast in a straight line
not gonna fit the ecu now as will need a diff loom and TP sensor.
a cam will help though, its a budget track car so cant go too mad.
bung a autosprint regring in it £90 job done run on standard mani aswell
Megasquirt it!Get some launch control and full throttle gear changes on the blend. lmao
