c20let problem
Results 1 to 10 of 10
Thread: c20let problem
    Sep 2008
    luton
    corsa gsi c20let
    c20let problem
    hi guys
    i have corsa b gsi c20let..... when driving normal the cars fine but as soon as you put your foot down and the turbo kicks in..... its like a constant flat spot / holding back... what could cause this ?
    Sep 2009
    Chelmsford
    Corsa gsi....
    Re: c20let problem
    Leaking turbo pipe maybe? So the turbo is spooling up ok?
    Sep 2009
    northumberland
    Re: c20let problem
    i had similar problem with a impreza(i know not vaux ralated sorry lol) and the problem i had was a split in the turbo pipe
    Sep 2008
    luton
    corsa gsi c20let
    Re: c20let problem
    hi guys...... no not one split in any pipes at all
    May 2005
    central scotland
    astra G coupe c20let
    Re: c20let problem
    not running lean is it
    MIGClub Member c20letian's Avatar
    Jul 2009
    Kent
    Calibra 4x4
    Re: c20let problem
    maybe wastgate creep...
    Mar 2009
    Paris Neighbourhood
    OPEL
    Re: c20let problem
    Hello
    It won't hurt you to check your spark plugs , maf sensor as well .
    Mar 2009
    Greece
    Calibra Turbo 4x4
    Re: c20let problem
    check the afm hose to turbo
    Sep 2008
    luton
    corsa gsi c20let
    Re: c20let problem
    checkd the hose form afm to turbo mate thats fine :S.......could it be the dizzy ?
    Sep 2008
    luton
    corsa gsi c20let
    Re: c20let problem
    if the timing belt was loose could it be this as i have about 1inch in play so replacing the belt... could that have caused it!
