need to sort my speedometer c20xe
Results 1 to 16 of 16
Thread: need to sort my speedometer c20xe
    Jul 2009
    leicester
    Purple Ronnie c20xe
    my corsa xe currently has no speedo cable so i never know how fast im going lol
    basically i need to know if there are different types of speedo cables for xe's and how to find out which one i will need if there is- also where can i get one from and how much approx? and how do i fit it? is it pretty straight forward?
    im asking a lot of questions today lol cheers lads
    Jay
    Jay is offline
    Oct 2008
    Kirkcaldy,Scotland
    Belmont Club. Corsa LET
    Re: need to sort my speedometer c20xe
    it can be mechanical or electric,and they are pretty straight forward to fit tbh
    can get them from scrappy for about 10-20 bucks
    Jun 2009
    Essex
    C20XE Mini Clubman
    as above..you need to find out if your dials are electronic or mechanical...then find the correct sender for the gearbox...tricky to explain but very, very easy to install electronic transducer or mechanical sender, they go into the same hole :-)
    Have you got a haynes manual? invaluable! search on fleabay and pick one up
    Matt
  5. Remove Advertisements
    Jul 2009
    leicester
    Purple Ronnie c20xe
    Thread Starter
    haynes manual? never heard of it whats that all about then...
  7. #5
    Nov 2007
    Leicester
    if you dont know what a haynes manual is then dont bother go to a garage!lol
  8. #6
    Jun 2009
    Essex
    C20XE Mini Clubman
    Quote Originally Posted by corsakristian View Post
    lol...you are joking? right?
    Matt
  9. #7
    Nov 2007
    Leicester
    i hope so
  10. #8
    Jul 2004
    2 Astras & 1 X-Type
    Although this is clearly for a MK1 Astra.
  11. #9
    Jul 2009
    leicester
    Purple Ronnie c20xe
    Thread Starter
    ohhhhhhh hahaha yeh sorry had a bit of a dick head moment lol excuse me haha
  12. #10
    Jun 2009
    Essex
    C20XE Mini Clubman
    you sure youre sure?
    good luck with the speedo
    Matt
  13. #11
    Jul 2009
    leicester
    Purple Ronnie c20xe
    Thread Starter
    right before i leave this topic alone i havnt discovered wether there is just one type of xe speedo or do i need a certain one depending on what engine type or transmission it is? and where exactly does the other end of the cable go? (the one that doesnt go to the gear box) because i just had a look in the haynes manual but it didnt say lol
  14. #12
    Jun 2009
    Essex
    C20XE Mini Clubman
    damn that haynes manual! however..as said a few times before you need to say if your dials are electronic or mechanical!
    there is a different sensor for mech and electronic
    wires from electronic transducer go to the loom on the back of your dials - haynes should have wiring diagrams
    Matt
  15. #13
    Jul 2009
    leicester
    Purple Ronnie c20xe
    Thread Starter
    right then... how do i know if it is electronic or manual? what should i be looking out for im a plonker with this sort of stuff
  16. #14
    Jun 2009
    Essex
    C20XE Mini Clubman
    look down at the gearbox and coming out of it will be the sensor (check haynes manual to find where it is on gearbox) if it is electronic there will be two wires coming out of the top (they will be flimsy, like, erm, wires lol) if it's mechanical there will be a far more rigid cable coming out of it (a bit like the housing for a bike brake cable)
    Matt
  17. #15
    Jul 2009
    leicester
    Purple Ronnie c20xe
    Thread Starter
    i have figured out that it is mechanical but i dont have the speedo drive or the cable so i need both lol someone has just plugged it up with a rubber bung
  18. #16
    Jun 2009
    Essex
    C20XE Mini Clubman
    i'm sure you'll be able to source a mechanical drive on ebay, might even be worth phoning some vauxhall specific breakers yards. I would have thought they are more common than the electronic variety. Fingers crossed :-)
