bad smoking from 1.6 16v
Results 1 to 15 of 15
Thread: bad smoking from 1.6 16v
    Mar 2008
    Newcastle Upon Tyne
    vectra cdx 2.5 v6
    Hi guys i recently bought a 03 plate zafira, its now smoking really badly, if i start it and let it idle nothing happens, but as soon as i rev it, it smokes like mad, it smells like oil and its got a blue tinge to it aswell.
    Its also misfiring at low revs but this could just be the coil pack or similar, any ideas as to what could be causing the oil burning
    mark
    Mar 2008
    Newcastle Upon Tyne
    vectra cdx 2.5 v6
    Thread Starter
    Re: bad smoking from 1.6 16v
    anyone
    mark
    Jan 2006
    Manchester
    04 Astra H 1.8 Elite
    doesn't do it at all when idleing?? could be a piston ring, would have thought if it was sumit like a valve seal it would do it worse when starting up due to oil seeping into the cylinder when its off, you checked the oil for water\petrol in it as it could be head gasket leaking oil into one or more of the cylinders when the oil pressure increases when revved, could one of a few things!
  5. Remove Advertisements
    Mar 2008
    Newcastle Upon Tyne
    vectra cdx 2.5 v6
    Thread Starter
    hi mate the water seems fine nothing nasty in there, ive tryed a new coil pack and the misfire is no different, so whatever it is, is causing the misfire. Ive also noticed that the timing belt cover has been smashed near the front cam pulley, not sure if maybe its just someones just done it accidently or if maybe the timing belts snapped??
    It does smoke on idle after its been revved for a first time but if i just start the car and never touch the throttle it wont put any smoke out
    Mark
  7. #5
    Dec 2008
    Southampton
    Astra 1.6 16v
    Sounds like the piston rings or the Valve stem seals are shagged
    Driving: MK3 Astra Sport 1.6 16v "Project Redrum"
    Fixing problems that shouldn't have existed since 1996
  8. #6
    Mar 2008
    Newcastle Upon Tyne
    vectra cdx 2.5 v6
    Thread Starter
    would you recommend new engine or should i get the head refurbed? also how hard is the piston rings?
    Thanks
    mark
  9. #7
    Sep 2003
    South London
    Without Due Care
    it depends on how much money and skill and time you have?, In alot of cases its Far easier to buy another engine, good/low milage, known working with warrenty for 250 to 350 (which is what i believe they go for) and fit it or have it fitted.
  10. #8
    Dec 2002
    S Wales
    TB'd Nova, S2000
    If it has a misfire and is smoking, its a piston - either has a hole in it, or the oil rings have gone -
    If you are good with spanners, rip the sump off and take the piston out and change it - this is a bit of a gamble as the bore may be damaged too, but you should be able to tell when the piston is out....
    If you arent so good, and that scares you - get a new engine!
    Too many Vauxhalls, not enough fuel.
  11. #9
    Jul 2009
    wellingborough
    timing cover smashed? possibly down to a timing belt jump? if its jumped previously, the owner may have timed back up in order to get it 'running' again and flogged on a sly one. could have a piece of valve bouncing around in there messing stuff up and scoring your bore. regardless of how sounds like it needs a good fooking rebuild or a new motor mate sorry to say. Similar thing happened to me with a fiat. seemed to run fine when i brought, then it started coughing out smoke and losing power. Eventually stripped to find foreign metal smeared along the bore and some nackered rings. win some ya loose some!
    !peace!
  12. #10
    Mar 2008
    Newcastle Upon Tyne
    vectra cdx 2.5 v6
    Thread Starter
    bought it to put a new engine in so no real loss really as i expected a new lump to go in it, never dropped a piston out but i can do headgaskets, cam belts and stuff but thats as far as ive gone so far so may have a bash at it. never ventured to the bottom end LOL!
    Its definatley got quite a bad miss and a real lack of power
    Mark
  13. #11
    Aug 2009
    immingham
    zafira gsi
    i did one of these for a freind and in the end it had a new engine .
    but we had everything done on the engine new rings new head gasket new head skim and pressure tet but it was stil the same so bang a new engine in and it will save you alot of hassle
  14. #12
    Mar 2008
    Newcastle Upon Tyne
    vectra cdx 2.5 v6
    Thread Starter
    looks like that way, cheers lads
    mark
  15. #13
    Oct 2005
    leigh
    corsaclet
  16. #14
    Oct 2005
    leigh
    corsaclet
    some old diesels do it that much oil bypassing the rings it starts running on it and revs to the sky, till it either burns all the oil and seizes or knocks a piston or two.
  17. #15
    Oct 2005
    leigh
    corsaclet
    ive got a x16xe bottom end for sale 50 from wn7 1ub, ran fine no smokewhen it last ran
  1. 24-10-2016, 05:24
