for c20let? Its £250 iirc and basically has 25% extra flow than a z20let oil pump that is commonly used on c20let's as an upgrade...SBD also gets them shipped in from europe hence u cant get it off the shelf at SBD.
i find it better using an original vaux pump, checked over with the inner steel gear from SBD, other than that dry sump which will be complete waste of money for your needs tbh
what oil pump would i use for a late block and an early crank setup? a late or early just before i go and buy one
