my sxi corsa doesnt like revving past 3500-4000 rpm, its runs good til the then seems to restrict itself from going higher, i have been told it could be the air flow sensor, is this likely to be the problem?
Could be the airflow sensor as you said, so I guess the first port of call would be to clean it, see if that helps. If there's no change, see if you can borrow one off a mate and see if that helps.
What induction system are you running? Standard airbox and filter/cone filter/uprated panel filter?
its only a standard air box and filter, had a look and it looks quite new.
