just finished getting it up and running! but it hunts sometimes and the eml flicks on/off! underload it caughs and splutters then clears and drives fine!
i have used the same parts that was on my old LET execpt the turbo...
then only thing i can find is a hose that looks like a map sensor but its not connected, all the vacuum hoses i know of are connected....shall i t it in a see what happens? is it from my old 14xe ecu+lump?
this is doing my head in! checked the timing and the inlet was slightly out so adjusted that, put it all back together and once it got to running temp it started messing around! i drove it for a good 20mins or so and it only done it 3 times!
its fine when cold the eml came on then it idled at 2k then it drops and drives normal again lol idle is a bit rough once hot though!
You could start it up and spray Ethenol (ie carb cleaner) into anything vacum/boost/air related. If the car rev's up when you spray a sirtan area then your problem will lie there.
reading an old tv mag earlier and your corsa was in there! when it had the red bonnet lol
mot tomorrow best pass lmao
