hi i have an astra mk3 with the x14xe engine every so often it just conks out when i put the clutch in as im slowing down does anybody have any ideas or has had this same problem please let me know asap as the things going to be drownd!
Did these engines use a vehicle speed sensor? This is the problem i had when the speedo cable snapped on my corsa gsi. It might have a mechanical speedo with an electric speed sensor on the gearbox end of the cable could be that mate, other than that try a new icv sometimes on ebay for cheap. I cleaned mine once to cure a high idle but made no difference ended up getting a new gm one for about £5 on ebay
i take it the engine is pretty much standard? my astra with a c14se did the same thing when it had a lairy cam in it.
