Now the LET wont go over 3k
Page 1 of 3 1 2 3 LastLast
Results 1 to 25 of 60
Thread: Now the LET wont go over 3k
    May 2008
    telford,shropshire
    astra mk3 GSI turbo
    got the let running sweet, well idleing sweet, but when i rev it it gets to 3k and dies, pretty much as soon as i open the throttle it burbles and dies and then just about ticks over
    help please as i cant miss billing, cheers
    Jan 2002
    ayrshire scotland
    like a saint-9points
    Re: now the LET wont go over 3k
    does it do it even just revving it or only when you drive?
    rodgerq
    May 2008
    telford,shropshire
    astra mk3 GSI turbo
    i havnt drove it yet, just on the drive until tomorrow, been told it could be the throttle position sensor????
    so im revving it on the drive, if i slowly rev it it will go right up to 6k, but as soon as i open it fully it dies
    Jan 2002
    ayrshire scotland
    try disconnecting the air flow meter and see if it makes any difference.
    rodgerq
    May 2008
    telford,shropshire
    astra mk3 GSI turbo
    it idles ok when connected but when i take off the afm it is even worse and wont rev at all really
    Jan 2008
    Bramley Leeds
    mk4 astra sri c20let
    fuel pump?
    May 2008
    telford,shropshire
    astra mk3 GSI turbo
    the fuel pump was new about 8 months ago
    May 2008
    telford,shropshire
    astra mk3 GSI turbo
    i can hear the fuel pump buzzing every so often on idle, even if its buzzing can it still be faulty, i just spoke to my mate who gave it me and he said it was used so unsure how old it is
    Sep 2007
    Buckley, North Wales
    astra sport 1.6
    throttle position sensor or mass air flow sensor is what it sounds like
    May 2002
    liverpool
    Zafira VXR STAGE 2
    do these have knock sensors? my xe wouldnt go past 4.5k til i changed it.
    Im a Daddy Wahoooo
    May 2008
    telford,shropshire
    astra mk3 GSI turbo
    well i changed the tps, cts, afm and still the same, im going to change the pump tomorrow but failing that could it be that the fuel has been sat for like 5 months in the tank but with it holding back when i put my foot down im thinking its not getting enough fuel so hopefully the new pump will sort it
    May 2008
    telford,shropshire
    astra mk3 GSI turbo
    can anyone help me on this, i couldnt make it to billing because i couldnt get it sorted,
    ive now changed the plugs, fuel filter, pump, cts, tps, leads, inlet gasket. ive got no air leaks and checked all boost pipes.
    the engine is dying as soon as the boost gauge gets to -10. dont even get to 0psi.
    basically pretty much as soon as i open the throttle it dies and then will idle very low but idles fine when first started. im really puzzled as to whats wrong, it ran perfect before i took it out for the car to be resprayed, all ive put on it is fmic and 2 1/2 boost pipes. and the phase 2 ecu with 3.5 bar reg.
    ive tried another ecu and still the same
    can the actuator being right at the end of the rod cause this???? i havnt set it up yet
    Mar 2004
    cumbria
    C20LET GT28 NOVA
    crank sensor, is one i would try my let did the same thing last year
    May 2008
    telford,shropshire
    astra mk3 GSI turbo
    will try one then mate asap cheers
    but if it was on its way out wouldnt the eml come on???? i got no eml showing
    Gagged
    Oct 2008
    argyll
    the eml may not come on till it completely fails.
    i also say knock sensor
    Jan 2007
    england
    dirty injectors ?
    May 2008
    telford,shropshire
    astra mk3 GSI turbo
    as far as i could see they were spotless when i put them back in, i kept them out the way of any dirt etc in bags and when they were fitted i checked them over. they worked fine before engine came out.
    MIGClub Member c20letian's Avatar
    Jul 2009
    Kent
    Calibra 4x4
    is the accuator fitted? and the turbo wont make boost if not on load...
    Jan 2002
    ayrshire scotland
    is the knock sensor plug and idle controlvalve plugs on the right way? ie red plug to knock sensor, black to ICV
    rodgerq
    Jul 2009
    Kent
    Calibra 4x4
    did you play with the cams?
    Jan 2007
    Nottingham
    Corsa C Z20LET 305BHP
    Would a blown turbo give you these simptons?
    Jan 2007
    england
    Quote Originally Posted by turbojay View Post
    well i ran my tank low once and after that i had engine troubles where it wouldnt go over 3000rpm. fine upto 3000, but wouldnt go over. i swapped to another set of injectors, cleaned fuel rail and fpr and it never did it since.
    i only said injectors cos your engine has been stood, deposits in the injectors/rail/fuel lines would turn into dust when the petrol has dried up. that muck could be giving you these problems. or maybe its another fuel system fault ? pump ? fpr?
    Jul 2009
    wellingborough
    had a similar sounding problem on X16XE, no turbo issues here was just dirty fuel, had fouled all plugs. Put 15 litres of 101 oct fuel in there, changed plugs and left to idle for about 30 mins took it for a spin and after a bit of rough running and popping she was sweet as a nut. Not sure how related this is but it wouldn't rev before i did this and had no power anywhere let alone bottom end when the baby valvers actually have **** all go anyway.
    Jun 2009
    Dartford, UK
    '98 Corsa X12XE
    Quote Originally Posted by rodgerq View Post
    rodgerq
    I agree with roger!
    AFM
    Da Mashan
    Look how nice the back of my car is... you'll be seeing it a lot!
  26. #25
    May 2008
    telford,shropshire
    astra mk3 GSI turbo
    ive tried 2 afm and its still the same, definate working ones too so not the afm, im going to put £10 of high octane fuel in tomorrow and give it a run
