Results 1 to 6 of 6
Thread: Found this in my sump - concerned - help please!
    Jan 2002
    Birmingham/UK
    YES IT WAS EXPENSIVE
    I am in the process of changing my sump on a 3.0 V6 but it has a 2.5 sump fitted and this was in the bottom of it with a bit of gunky oil.
    All I can tell you is:
    Its made of Aluminum
    there is no thread on it
    looks to have a small hole punch effect in the center of it.
    Any ideas would be very helpful! I am guessing its from the sump as its ally but it can not be good surely?
    ::: Designed For All Astra Drivers - astraownersclub.com :::
    MIGClub Member corsadonk's Avatar
    Jan 2009
    Wiltshire
    Corsa TD, DC2 ITR.
    Re: Found this in my sump - concerned - help please!
    NICE! Must be a new oil addaitive
    Jan 2002
    Birmingham/UK
    the only possible thing I can think off, is it could be from where the oil feed for the charger has been put in. However that would have been drilled and tapped through surely? Unless the hole was already there (but smaller for something else on the sump in OE format??) and they have drilled, pushed through and made the hole larger?
    Purely guessing.
    Jan 2002
    Birmingham/UK
    looks like this is the culprit:
    which is less of a worry, still shouldnt be there but at least I found it.
    Jun 2000
    Hampshire, UK
    Vectra SRi
    Who drilled the sump and put it all back together Matt?
    Jan 2002
    Birmingham/UK
    it wasnt me!
