What engine to use?
Right, my apprentice's corsa has took the knock it is one of those 1.0 3cyl jobbies in a 04 plate corsa. We cant get i direct replacement any where.
What i need to know is what other cors engines will mate to the box? I havent even looked at it for him yet. Do these have FBW or a conventional throttle wire? I was thinking of a 1.4 or summit like that. I pressume these can be sourced fairly cheap these days.
So to sum up
Will a corsa 1.4 or any other engine mate to the 1.0 box? Recommendations?
What will i need?
Engine mounts? Exhaust? Ecu, Transponder? Key chip?
Re: What engine to use?
all stop panicking,,,,, ive sorted it lol
