Basically I bought my first ever vauxhall last night for work. A 1.7td 1999 v reg astra van.
I now have a fault that is doing my nut in and too bad to ignore.
In the morning the car starts fine first time, ticks over etc fine and has such a smooth engine.
If you rev when cold lots of smoke shooting from the exhaust black.
If you drive for a while it all changes, when the car gets warm (needle shows between 80-90, and doesnt sit still), the car start to hesitate as your driving, a little loss of power., and sometimes jurking.
If you stop when the car is warm and let it idle its idleing low like its about to cut out and then jumping up, doing this repetedly, like your sitting there revving it your self (but im not)
This then stops if you put your foot on the accelerator pedal. Also its not smoking as much when its warm.
Dash light wise, i get two lights come on when the problem is there (when warm, never when cold). one is the bottom left light, looks like a rad with fan in front of it, and the other im not too sure what it is, its under the handbrake light and to the left of the battery light.
Again the car is idleing fine and driving fine when cold, bar the smoke, untill it gets warm, when the symptoms above start and lights come on.
Last thing is very rarely when this bunny hoping idle is happening, the speedo moves to about 5mph and drops again. Only rarely.
Any idea on this people? help would be so appreciated.
Going to give the throttle etc a clean tomo, but need a haynes, dont know where any thing is on this engine. (usually have Vw's)
Thanks in advance
Rest assured that it will give up on you when you're 400 miles from home. lmao
