hello! i have single fogger wet kit and i want to install it on let.
specs of my let:
wassner pistons with arp's, xe camshaft, eds phase 1 chip, 2.5" intake, evo cooler, 3" straight exhaust.
also want to install saab injectors, flowing 359cc/min, may be running on 3.5 bar.
i read this instruction and have some questions.
http://www.holley.com/data/Products/Technical/199R10295.pdf
page 16,17.
1)will i need in ignition timing change? i know, that stock ecu control ignition. but how fast it do that?
2) which sizes of jets i must use? for example, 36 n2o with 20 on fuel (3.5 bar on fuel +0.9 on boost). is it correct?
3) how much HP i can safely inject on my engine config?
big thanks!!!
specs of my let:
page 16,17.
big thanks!!!
