Anybody good with gearboxes? I want to put a wide ratio 5th gear (from F10) into a F13 (close) box - both gears are easily removable from the end of the box with it in the car I reckon - I already have the 5th gears removed from the F10 ready to go.
The part numbers for The F13 close ratio from the Nova are the same as the Corsa C ones, according the my parts catalogue, and as far as I'm aware, the F10 and F13 are almost the same, bar a few bearings being bigger in the input shaft and the bellhousing being a touch bigger too.
Can anyone confirm my idea that the F10 / F13 are basically the same? I imagine that the 5th gears would be the same, as they generally have an easy life.
Any help gratefully received!
Steve
Steve
