its on an early xe engine, but the altenator is covered in dirt, so cant read much on it. im looking for a new belt so what is likely going to be the power rating?, so i can look for some sort of figure. cheers
just had a look on the altenator itself, and found this:
so i take it its a 100v?!
Also another question, i have two tps, both 3 pin, but they are different sizes, any reason for this ( i thought the diference between tps were different number pins?? )
First pic' is of the suppressor - it's to reduce voltage spikes and so interference through the radio/stereo system.
The alternators I have have the alternator rating and model etched by one of the mounting ribs. You may be able to clean it up enough with some alloy wheel cleaner so you can identify it - may not as it isn't etched very deep and may have been erased by sorrosion.
Oh, if you just want to replace the belt, you should have an identifying number on the old belt - either quote the number or take it in when purchasing a replacement.
