How to megasquirt a Vauxhall engine, with MS2 v3
Page 4 of 4 FirstFirst 1 2 3 4
Results 76 to 82 of 82
Thread: How to megasquirt a Vauxhall engine, with MS2 v3
  1. #76
    Oct 2002
    Near Gatwick
    2litre 8v turbo mini
    Re: How to megasquirt a Vauxhall engine, with MS2 v3
    cool, get full version of tunerstudio and get driving
    youtube.com/mattgreen16v : Classic Mini Restoration
    Jan 2016
    Barnsley
    Subaru Impreza WRX Bug Ey
    Quote Originally Posted by 16vmini View Post
    What are the extras that are included in this? Im still getting to grips with the Open/Closed loop learning part im assuming this is included in the full version.
    Cheers
    Mike
  4. #78
    Oct 2002
    Near Gatwick
    well apart from giving the guy some money who wrote it , you get lots of extras ,
    TunerStudio 3.0 Features by Edition | tunerstudio.com
    the main thing is VE analiser live , so will self tune while monitoring wide band ,
  5. Remove Advertisements
    Jan 2016
    Barnsley
    Im having a few problems getting my engine to rev.
    Have I got my engine constants right here?
    Control Algorythm: Speed Density
    Primary Igntion Load: Speed Density
    Secondary Fuel Load: Speed Density
    I feel as though these are wrong but when I change any of them my ecu throws a wobbler and says there are conflicting settings.
    Thanks
    Mike
  7. #80
    Oct 2002
    Near Gatwick
    start with the basics , are you getting a good crank signal ? check tooth logger ... prove that is nice and clean first. most times when i cant rev , its due to bad crank signal
  8. #81
    Jan 2016
    Barnsley
    I will do mate.
    I think I need to set my Control Algorythm to Percent Baro.
    and my Igntion load to MAFMAP.
  9. #82
    Jan 2016
    Barnsley
    Right just incase anyone else has this issue. Basically the car would fire up but backfire on tick over and wouldnt rev.
    Turns out my Crank sensor wires were wired back to front. Swapped them over and the car now idles and revs nicely
    Thanks
    Mike
  1. 23-02-2016, 11:55
  2. 21-09-2014, 17:16
  3. 11-01-2014, 02:38
  4. 13-01-2013, 01:44
  5. 05-12-2012, 12:52
  6. 04-01-2012, 22:15
  7. 04-04-2011, 08:26
  8. 06-01-2011, 13:42
  9. 12-10-2010, 04:03
  10. 31-03-2010, 03:22
  11. 14-03-2010, 20:08
  12. 25-12-2009, 18:08
  13. 28-05-2009, 07:00
  14. 17-05-2009, 19:40
  15. 17-05-2009, 19:38
  16. 02-04-2009, 17:45
  17. 07-02-2009, 19:11
  18. 06-02-2009, 18:09
  19. 05-02-2009, 16:15
  20. 05-02-2009, 15:05
  21. 05-02-2009, 14:55
  22. 10-01-2009, 00:01
