I can hear my tappets!
Results 1 to 14 of 14
Thread: I can hear my tappets!
    Dec 2000
    Gloucester
    3MW B18iS
    When I start up they rattle for 2-3 seconds. No big deal.
    But I've started to hear them other times, after revving the engine a fair bit. It goes soon enough, but is this normal?
    It could be to do with the loss of sound proofing, so I can hear what the engine is up to lot more clearly now.
    What else could it be? Oil pressure is fine and it's new 10W-40 Magnatec, as per normal.
    Maybe I should replace them when I'm feeling flush with cash later in the year?
    No, now f*** ***.
    Dec 2000
    Gloucester
    3MW B18iS
    Thread Starter
    Cmon then? Am I going mad or is just a sign that the engine's gonna blow?
    No, now f*** ***.
    Feb 2002
    Fareham, Hants.
    C20XE 13S Z20LER Z17DTH
    Hmm, are you sure it's tappets and not just summink that's rattling away at certain revs? The cam on the Astra seems to make a crinkly rattley noise at ceertain revs (no, not pinking).
    Could be your cable-tied-to-column-clocks?
    They're there, in their room.
  5. Remove Advertisements
    Dec 2000
    Gloucester
    3MW B18iS
    Thread Starter
    Or the ****y Alternator maybe? Think I'd better check properly then.
    No, now f*** ***.
  7. #5
    Feb 2002
    Fareham, Hants.
    I had this when I bought the Astra (3 years ago). First I thought the water pump was knackered. Replaced, noise caried on. Alternator? Got one from scrappy, noise stayed. Drove with NO alternator at all. Noise still there.
    It's the poxy cam belt cover. Try driving without one?
  8. #6
    Oct 2000
    Bracknell
    Mondeo, MR2, Manta
    dude, you need more important stuff to worry about lmao
    but i wouldn't stress unless you hear them when you're driving
    Originally Posted by Brian_S: Woooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo!
  9. #7
    Apr 2002
    Brazil, São Paulo
    Astra GTE 2.0 8V Tur
    Maybe is the "small shapes"(i don't know correct name) moved fromn correct place of tappets.
    I had this problem in my car. When you use a lot of in high rpm, can happen this.
    Remove valve cover, and see if all things are ok. Rocker arms can crash too.
    I hope is nothing serious.
  10. #8
    Dec 2001
    Chelmsford, Essex,
    Astra1.8, Zaf1.8/1.9CDTI
    There are no rockers on a VX DOHC engine.
    Wouldn't worry even if it is tappetts, they go on tapping forever, just another annoying noise!!
    Get a Cone filter, bigger exhaust, or turn the stereo up!
    Could also be manifold gasket. Is it worse under load?
  11. #9
    Northeast Kent
    Originally posted by Mark CDX V6
    There are no rockers on a VX OHC engine.
    yes there are. 8v cams dont ride directly over the valves, it cant cause they are offset. the cam rides on the middle of the rockers, the rockers rear end sits on the knuckle ontop of the hydraulic lifter, then the other end of the rocker presses valve open via thrust pads between the rocker and valve stem.
  12. #10
    Dec 2001
    Chelmsford, Essex,
  13. #11
    Jul 2000
    Mark - stickers car is an 8v
    BRB
  14. #12
    Mar 2001
    London
    Audi S4 Biturbo
    Loosing a valve thrust pad ends up with a loud ticking noise that doesn't go away.
    Had fun putting one back in with just the rocker cover off. Right i'll push the valve down.... you slide it in...
  15. #13
    G51
    G51 is offline
    Jan 2002
    Honda Prelude 2.2 VTi
    could it be the injectors your hearing ticking away? I used to hear them on my SRi.
    www.freewaycars.com
    29 PEOPLE WANTED to earn £££ & lose upto 30lbs
    Dr recomended
    You or somebody you know may need to lose weight, gain energy or just improve your health.
    Call now
    020 7863 3676
  16. #14
    Dec 2000
    Gloucester
    3MW B18iS
    Thread Starter
    I can hear the injectors but that's a different noise.
    Fear not, I will take the rocker cover lid off and have a look on SatRday.
    No, now f*** ***.
