Well i'v recieved a few PM's latly about mk4 redtop conversions so iv compiled most of what i know into a hopefully useful guide
Wiring:
Same as mk2/3 to clocks, (rev counter, eml, oil light) , but dont wire up the water temp gauge(they work on milliamps from their own ecu on mk4s) so just stick a temp gauge in somewhere else.
Wire up your own external fuel pump straight to the fuel pump relay. Disconnect the radiator fan from the ecu it normally runs through and use an in pipe adjustable fan switch(from demon tweaks) and keep the mk4 radiator, then obviously the Xe ecu live and earth.
Keep the Mk4's original alternator starter and the wiring with it.
Gearbox:
Use an F23 from a 2.0 dti or 2.0 16v mk4 (2.2 astra and all vectra B boxes do not fit) also use the shafts for that box, the clutch pipe will connect straight up
Engine Mount:
This is the bit where i think you might get stuck, every c20'd mk4 iv worked on/helped build has had the timing changed to LATE type, a hole cut in the front and back cam covers a hole tapped in the block and a half the standard mk4 mount fitted and half a diffrent mount but i dont know what the mount was from. Heres a picture of the part number that might help, cant really make out the numbers that well though.
Or i have heard about people welding a bracket to the underside of the chassis leg but dont have any more info on that one.
Other issues you might come across: Top hat, lose the sfi box and use one for a corsa conversion. Rear water hose(the plastic one) needs changing for a diffrent one, but ill find out what one it is.
heres a bit of inspiration lol
apart from that it should be pretty easy to figure out.
If any body wants to add to or correct me then either post or PM me
hopefully this will help peopleany other questions keep to this thread please
Bucky.
