Go Back   MIG Performance Vauxhalls > MIG Technical > Engines and Transmission
Engines and Transmission Technical forums for the discussion of all engine, transmission, turbo, ECUs, fuel systems and the like.
Old 07-10-2008, 20:15   #1
Drives: corsa gsi c20let
Unhappy speed sensor corsa c20let where???
eml light is on coming up with code 24 speed sensor where is it dose it come from the clock area or gear box? or have i just for got to wire it in
stevadunn is offline   Reply With Quote
Old 08-10-2008, 14:01   #2
Question Re: speed sensor corsa c20let where???
bttt
Old 08-10-2008, 14:46   #3
Drives: '00 Astra 2.0 SRi
the ECU takes a signal from the speedo clocks.
Vauxhall history : 13S | 14NV | C16XE | X20XEV
Big Col is offline   Reply With Quote
Old 08-10-2008, 14:46   #4
Drives: Corsa Tbo n Prelude
engine speed or vehicle speed?
Bring back the power of LET
vxlgsi is offline   Reply With Quote
Old 08-10-2008, 15:16   #5
vehicle speed and ma speedo is ran by cable if it makes any diff
Old 08-10-2008, 15:17   #6
Drives: corsa SXi
is it cable clocks or electric clocks with a transducer. Cable clocks have a speed sensor transducer built in as Col has said. The later cars had electric clocks and you have to fit a transducer to the F20 to drive them. If it was faulty then the speedo wouldn't work either I wouls have thought.
edit I see you have cable clocks, in that case the speed signal should come from them.
AJBek is offline   Reply With Quote
Old 08-10-2008, 15:20   #7
so dose that mean a need a set on new clocks
Old 08-10-2008, 15:40   #8
could come from the abs if you have it
Old 08-10-2008, 16:11   #9
has abs so would that mean one of the abs sensors is f**ked
Old 08-10-2008, 16:23   #10
AFAIK Corsa B's don't use the ABS for the speedo signal.
Does your speedo work ok? Next to check is the speed signal wire. I'm sure i read on another post its a blue & red wire. Is it connected?
Old 08-10-2008, 16:26   #11
speedo works where would i find this wire is it down next to ecu where i joined the rest of c20let loom
Old 08-10-2008, 16:27   #12
plus a think the speedo is out a canny bit if that would make any diff
Old 08-10-2008, 16:27   #13
sorry, can't help you there
Old 08-10-2008, 16:56   #14
tt
Old 08-10-2008, 17:44   #15
Drives: ASTRA GSI 93'
are u havin a head ache steve mate its dava
RRRachael_GSi is offline   Reply With Quote
Old 08-10-2008, 18:04   #16
tis the red and blue wire mate, should be one in the corsa loom in the drivers footwell, and one in the c20let loom just join it up.
speedo will read wrong if you have an f28 box and havnt changed the drive on the diff for one from an f20 box.
Old 09-10-2008, 12:04   #17
running a f20 box and the red and blue wire (thick one) is fuel pump yes?
and the thin one must be the one you are on about
will check in a min
cheers
Members: 42,529
Threads: 308,061
Top Poster: LEE69 (42,902)
Welcome to our newest member, Kadettoulas
