Go Back   MIG Performance Vauxhalls > MIG Technical > Engines and Transmission
Engines and Transmission Technical forums for the discussion of all engine, transmission, turbo, ECUs, fuel systems and the like.
Old 07-10-2008, 11:17   #1
Drives: corsa turbo, skyline
fao omex ecu users
just purchased an omex 600 series ecu for my let but need to no the procedures to be taken to fit it, aparently it has a base map on but i have been made aware that omex have had issues with this and it may not be the case of having a base map so i would be trailoring it to the rolling road, but.... before it goes i would want to make sure it starts so i didnt waste mine or the tuners time, has anybody in the midlands area used omex and where have they been to have it mapped?
heres a quick pic of my system, will i be needing to add anything else to this, im planning on ditching the afm and running a coilpack instead of distributor, il also be using an apexi avcr to control the boost.
cheers jamie
jamie gsi16v is offline   Reply With Quote
Old 07-10-2008, 12:08   #2
Drives: 1993 Cavalier ST
Re: fao omex ecu users
Hi Jamie
1) They don't xome with the base map. you need to speak to Chris at Omex and he will email it to you.
2) I used Noble Motorsport up North. They knew what they were doing and I am happy with what they did.
The base map, is what it is. It only starts the car up. You can not do anything else with it. But if you take it to someone who know what they are doing, then I am sure they can even put a start up map in there.
I have my map that I am more than happy to send you. but it was obviosuly tailored for my LET and your specs may be different. I did also use the coil pack from the XE in my let and ditched the AFM and coil.
PM me if you want any more info.
nariman1977 is offline   Reply With Quote
Old 07-10-2008, 12:25   #3
Drives: 1.8 Corsa SRi
give aaron from city styling a call on 07531350436 (based midlands too ) say matt solly sent you
he will be able to sort it out for you mate
180+bhp Corsa C
solly is offline   Reply With Quote
Old 07-10-2008, 12:40   #4
Originally Posted by nariman1977 View Post
Hi Jamie
to get a coilpack working is it just a case of mounting it and plugging it in? not got my omex through yet so havnt had chance to look at the loom, what do you do about a map sensor?
Old 07-10-2008, 13:41   #5
Drives: Corsa B LET
yes just a case of mounting coilpack and wiring it in.
map sensor depends on how much boost you want to run,
i would get a 3bar map sensor which will allow you to run 2bar of boost iirc
i could send you my map if you wanted, should get your car running and drivable but wont be safe to put your foot down
street racers in leicester will map it for you if you wanted and he would be willing o give you any help you might need if you give him a call!
fray is offline   Reply With Quote
Old 07-10-2008, 16:22   #6
cheers fray so at the moment im looking to contact
street racers
noble motorsport
and omex themselves
wheres best to get a map sensor from?
Old 07-10-2008, 17:10   #7
street racers
noble motorsport
and omex themselves
Add Track 'n' Road to that list.
Uses standard GM sensors, usually with a siemens coil (had bad experiences with pattern coils) weber map sensor.
Steve
Pub Talk BHP Is All That Matters , One Valve Is All You Need.
No Text Messages
steveboyslim is offline   Reply With Quote
Old 07-10-2008, 21:29   #8
(future referance for other users) at the moment im looking to contact
street racers
noble motorsport
and omex themselves
track and road
and then go for a weber map sensor 3 bar??
and a seimans coil (can they be found second hand or buy new from where)
what do i use for a blanking plate where the dizzy was?
i have found out you can ditch the idle control valve but is this really worth it?
and its also fine loosing the air flow meter
i should think its best to use my apexi avcr as a boost controller evan though the omex has a boost controller just so its easily adjusted in car on the apexi instead of getting a laptop in and loading programs etc
Old 07-10-2008, 21:31   #9
Drives: White 1.6 16v Nova
Buy a plate from sbd etc to blank the dizzy hole.
Or just get one off a dispak xe.....
I think the std xe/1.8-2l ecotec coilpacks are 3wire siemens items
LongLiveTheNova is offline   Reply With Quote
Old 07-10-2008, 22:51   #10
Drives: Astra GSi 2.1 Turbo
so it you that out bid me on the omex!!! git lol
5am isnt half a strange time to end an auction!
M19 ROO is offline   Reply With Quote
Old 08-10-2008, 05:51   #11
lol
Members: 42,530
Threads: 308,061
Top Poster: LEE69 (42,902)
Welcome to our newest member, DENTYSXI
