06-10-2008, 22:42
#1 | | MIGWeb User
Join Date: May 2008 Location: telford,shropshire Drives: astra mk3 GSI
| couple of LET questions as myastra LT has been on the road for a week or so now i have noticed a few problems,
1. the engine management light is on when the car is first started then goes out after approx 10 mins of driving (basically when its hot)
2. when i first start car, mainly when its cold in the morning the engine seems to splutter when i pull off but again is fine when it warms up.
3. lastly the oil light keeps flickering on and off, (thinking its the sensor) as im using my old starter loom that was on my old engine and it was fine then or could it be the pump on its way out giving low oil pressure
thats about it, any help would be appreciated
thanks |
06-10-2008, 23:02
#2 | | MIGWeb User
Join Date: Dec 2006 Location: south Drives: vaux corsa b
| Re: couple of LET questions 1 and 2 could be related to the coolent temp sensor being on its way out, making it overfuel when cold n making it splutter.
3 i had this and it was because the little wire going to the sensor became unplugged, as soon as it was back in was fine |
07-10-2008, 07:07
#3 | | MIGClub Member
Join Date: Feb 2006 Location: Norwich Drives: to get more petrol.
| Re: couple of LET questions If the EML is on for 10 minutes read the codes!
__________________ 1993 Calibra turbo. Spare engine in the dining room. |
07-10-2008, 09:27
#4 | | MIGWeb User
| Re: couple of LET questions mine does a similar thing in the morning when cold, splutters and hesitates, idles perfect, but doesnt want to go and will kangaroo until temp has come up a bit.
which coolant temp sensor should i be using, a geniune vauxhall one? if so how much are they? |
07-10-2008, 09:51
#5 | | MIGClub Member
Join Date: Apr 2002 Location: Southwest Drives: Like its stolen
| Re: couple of LET questions As above, if the EML light is on, then ask the ecu why! |
07-10-2008, 18:32
#6 | | MIGWeb User
| Re: couple of LET questions Quote:
Originally Posted by maldred mine does a similar thing in the morning when cold, splutters and hesitates, idles perfect, but doesnt want to go and will kangaroo until temp has come up a bit.
which coolant temp sensor should i be using, a geniune vauxhall one? if so how much are they? | yeah exactly the same as what im getting, idles fine, just when i pull off.
chip i am going to do the test on the ecu to see what fault codes i get the weekend, just wanted to know if anyone had these probs before and new what could be wrong. |
07-10-2008, 18:45
#7 | | MIGWeb User
| Re: couple of LET questions ive changed the coolant temp sensor, even tho both my sensors are giving of normal readings on the multimeter. it still does the same when cold. ive lived with it up until now but it is annoying.
im thinking of changing the air intake temp sensor in the tophat. ive already had my ecu code read twice with no faults comming up.
any other ideas of what else to change? |
07-10-2008, 18:57
#8 | | MIGWeb User
| Re: couple of LET questions well im going to get a diagnosic on my car the weekend and if it aint the CTS then i will let you know what it is. |
07-10-2008, 22:01
#9 | | MIGClub Member
Originally Posted by turbojay well im going to get a diagnosic on my car the weekend and if it aint the CTS then i will let you know what it is. | Are you aware of the paperclip test? www.topbuzz.co.uk go to the 'Info tech section', then scroll down to 'reading ECU fault codes'
That'll save you £50. |
07-10-2008, 23:58
#10 | | MIGWeb User
Join Date: Dec 2004 Location: plymouth Drives: Astra GSI LET SCRAPD
| Re: couple of LET questions yes paperclip test FTW... when buying a new Coolant Temp Sensor make sure you allways get a genuine vauxhall one, last time i bought one it was £9.51 + vat. so about 11quid from vauxhall |
08-10-2008, 08:59
#11 | | MIGWeb User
| Re: couple of LET questions Problem seems to have gotten worse, this morning it was struggling to idle properly until it warmed up. when moving off with a little throttle it wouldnt rev! was a bit of a nightmare to get going, but again ran fine when warmed up. |
08-10-2008, 10:32
#12 | | MIGClub Member
Originally Posted by maldred Problem seems to have gotten worse, this morning it was struggling to idle properly until it warmed up. when moving off with a little throttle it wouldnt rev! was a bit of a nightmare to get going, but again ran fine when warmed up. | and yet you still havent bothered to flash the codes?
strange person |
08-10-2008, 10:39
#13 | | MIGWeb Moderator
Join Date: May 2003 Location: Nottingham Drives: Mk3 Astra LET
| Re: couple of LET questions Got to agree with Chip here. Reading the codes take a couple of minutes and will give you an idea of the problem. The time it took you to post could have been spent with a paper clip.
__________________ MIG Performance Vauxhalls
Moderator / East Midlands Regional Coordinator |
08-10-2008, 10:50
#14 | | MIGWeb User
| Re: couple of LET questions guys ive already code read the ecu 3 times there are NO fault codes!!!!! im not an idiot do you not think i would of tried that already??!! |
08-10-2008, 10:54
#15 | | MIGWeb Moderator
Originally Posted by maldred guys ive already code read the ecu 3 times there are NO fault codes!!!!! im not an idiot do you not think i would of tried that already??!! | I had mistaken your thread crash and thought you were the original poster. Maybe starting your own thread would save future confusion. |
Members: 42,363
Threads: 307,202
Top Poster: LEE69 (42,850) | | Welcome to our newest member, novadunnit16 | | » Join MIGClub Today | Join online
now!
of being a MIGClub Member.
