06-10-2008, 20:02
#1 | | MIGWeb User
| let ecu got a problem  my ecu has no sticker/lable  how can i tell what chips i need?
the ecu came with no chips ive got the ecu apart ...can i tell by looking
thanks wayne |
07-10-2008, 12:34
#2 | | MIGWeb User
| Re: let ecu or will any chips work?  |
07-10-2008, 12:35
#3 | | MIGWeb User
Join Date: Feb 2005 Location: derbyshire Drives: corsa turbo, skyline
| Re: let ecu think evo 5s work in anything, speak to beardy on here he will sort you out. |
07-10-2008, 12:55
#4 | | MIGWeb User
| Re: let ecu im after a set of evo 5's off beardy, ive tried pm him but no reply as yet, if you see this can you contact me beardy,
many thanks |
07-10-2008, 17:11
#5 | | MIGWeb User
| Re: let ecu i sent pm no reply as yet? any one |
07-10-2008, 17:22
#6 | | MIGWeb User
| Re: let ecu double post
Reason: double post
07-10-2008, 20:18
#7 | | MIGWeb User
| Re: let ecu me also no reply |
07-10-2008, 20:21
#8 | | MIGClub Member
Join Date: Dec 2002 Location: Essex Drives: 1.0 12 V Corsa
| Re: let ecu If your ECU has been repaired at some point , they usually paint it silver and put their own label on it .
I got some chips of Lee ages ago and he didn't even ask an ECU number and I fitted them and they worked fine .
Thing is though after fitting the chips , turn the ignition on without starting , if the engine management light comes on then you are ok . |
07-10-2008, 20:57
#9 | | MIGWeb User
| Re: let ecu Quote:
Originally Posted by daddy cav If your ECU has been repaired at some point , they usually paint it silver and put their own label on it .
Thing is though after fitting the chips , turn the ignition on without starting , if the engine management light comes on then you are ok . | its a remanufactured unit with atp sticker on it .....  xebm3585
how much r his chips?  |
07-10-2008, 21:06
#10 | | MIGClub Member
| Re: let ecu ATP are ECU repair company so yes , had a Cavalier GSi with a modified ATP unit that revved to 7500rpm .
If in doubt phone ATP they are a good company .
As for Lees chips , this was ages ago and he doesn't own a Vauxhall anymore . |
08-10-2008, 18:26
#11 | | MIGWeb User
| Re: let ecu Quote:
Originally Posted by daddy cav ATP are ECU repair company so yes , had a Cavalier GSi with a modified ATP unit that revved to 7500rpm .
As for Lees chips , this was ages ago and he doesn't own a Vauxhall anymore . |  shame its not got chips in ........any ideas what chips will work? |
08-10-2008, 20:46
#12 | | MIGWeb User
| Re: let ecu evo 5s will be fine mate |
09-10-2008, 20:19
#13 | | MIGWeb User
| Re: let ecu Quote:
Originally Posted by jamie gsi16v evo 5s will be fine mate | just found out my ecu is 95>later ecu  .......will evo 5 overide immobiliser  or
is it? i think its hd type ecu
thanks wayne |
09-10-2008, 21:21
#14 | | MIGWeb User
Join Date: Apr 2008 Location: birmingham Drives: vectra cdti sxi 120
| Re: let ecu yes m8...the imobaliser will be gone  |
Members: 42,530
Threads: 308,061
Top Poster: LEE69 (42,902) | | Welcome to our newest member, DENTYSXI | | » Join MIGClub Today | Join online
now!
of being a MIGClub Member.
