Go Back   MIG Performance Vauxhalls > MIG Technical > Engines and Transmission
Engines and Transmission Technical forums for the discussion of all engine, transmission, turbo, ECUs, fuel systems and the like.
Old 06-10-2008, 19:12   #1
Drives: 96' Corsa Sport
Corsa 2.0 Ecotec engine mounts
Can somebody please show me which mounts I need to buy from Chris Astley if I'm fitting a 2.0 Ecotec into my Corsa B Sport.
Cheers
jonshepherd is offline   Reply With Quote
Old 06-10-2008, 19:26   #2
donvaux's Avatar
Drives: Corsa GSI c20let WIP
Re: Corsa 2.0 Ecotec engine mounts
http://www.chrisastleymotorsport.com...uc6g4mmc0s8v96
If in doubt give it a klout
donvaux is offline   Reply With Quote
Old 06-10-2008, 19:36   #3
Ok is this definatly all I need? Spending 90 hard earned notes here!
Old 06-10-2008, 19:39   #4
donvaux's Avatar
that is all you need to mount the engine yes
Old 06-10-2008, 19:41   #5
donvaux's Avatar
sorry you'll also need this rubber mount, i thought it came in the kit
Old 06-10-2008, 20:02   #6
Where does that rubber mount fit in? My Corsa already has one in the o/s/f wing?
Old 06-10-2008, 20:05   #7
donvaux's Avatar
is your car a 16v if so it'll have an engine mount recessed into the chassis leg, with the kit you get a new mount that gets rid of your rubber mount and you have to use this one
Old 06-10-2008, 20:08   #8
donvaux's Avatar
does your mount look like this
Old 07-10-2008, 16:40   #9
Yea mate...
So I need both of those parts?
Old 07-10-2008, 21:24   #10
Is there not a simple set guide for these mounting kits?
Members: 42,530
Threads: 308,061
Top Poster: LEE69 (42,902)
Welcome to our newest member, DENTYSXI
