| Re: 93 Cavalier 1.8i LS advice I started out with the same engine, the C18NZ/90bhp (some 11 years ago) in one of my Cavs, no matter what I did to it little changed, its severly restricted by the single point inj.
As above the 20SEH (pre Aug 92 SRi 2.0 8valve) is a cracking engine, you can pick em up for next to nothing, its an instant 40bhp increase & its pretty easy to fit + you don`t need a cat on these engines.
If its purly insurance stopping you swapping the lump I can`t see there being a vast difference in cost, you could always tell em its the lower power C20 NE (a solid lump as well) in there  , the two engines look indentical.
Rich
__________________ 3.0 V6 Mk3 Cav - Saab B308I, F28, XE flywheel, Wilwoods
FWD Cav 16v Turbo - T34, water inj, 26psi, F28, LSD, Speedlines |
