06-10-2008, 14:40
#1 | | MIGWeb User
| astra gsi let f28 problem Hi guys i have a 92 astra gsi with let conversion and f28 gearbox,my problem is that reverse 1st and second are hard to get you have to fiddle around and apply a fair ammount of pressure to engage it,once in a blue moon it will go in a bit easier but this is very rare,the box was rebuilt about 8 months ago and has no whines or crunches,do you think this could be linkage related or wrong gearoil etc,and help greatfully recieved cheers neil. |
07-10-2008, 20:37
#2 | | MIGWeb User
Join Date: Aug 2006 Location: newcastle Drives: mk3 astra gsi turbo
| Re: astra gsi let f28 problem try a thinner oil that may help or the clutch cable might need adjusting a bit |
07-10-2008, 20:55
#3 | | MIGClub Member
Join Date: Mar 2006 Location: Wemyss Bay/Invercyde Drives: MK3LET/Estate/CBR600
| Re: astra gsi let f28 problem Try and re-set your linkage, I had a similar problem only today. turned out the 13MM Bolt that pinches the Gearstick shaft had slipped a wee bit. |
07-10-2008, 21:09
#4 | | MIGClub Member
Join Date: Nov 2005 Location: Durham Drives: 1.4 Corsa (Honest)
| Re: astra gsi let f28 problem Your linkage needs setting up again as I have just had same problem on my Corsa LET |
07-10-2008, 22:38
#5 | | MIGWeb User
| Re: astra gsi let f28 problem Excellent cheers guys,ive noticed to day that the gearstick sits futher forward than it should so i think that backs it up,also i noiticed its easier when warm,i spoke to vauxhall and they said it should run dextron2,now some years back i had a cossie and this had a similar fault,when checked it had a 80/90 in soo swapped it for dextron2 and was spot on,any advice either pro or against aforementioned vx tech please post as will be doing the oil swap at the weekend all being well and not pouring down again.  |
08-10-2008, 18:50
#6 | | MIGWeb User
| Re: astra gsi let f28 problem bump thought id also add i adjusted linkage today is so much better through gears and lots more precise but still hard to get in reverse if engine no |
08-10-2008, 18:52
#7 | | MIGWeb User
| Re: astra gsi let f28 problem sorry if engine on and 1st and 2nd sometimes need a push but not all the time and no crunches also better when warm |
Members: 42,530
Threads: 308,061
Top Poster: LEE69 (42,902) | | Welcome to our newest member, DENTYSXI | | » Join MIGClub Today | Join online
now!
of being a MIGClub Member.
