30-09-2008, 15:13
#1 | | MIGClub Member
Join Date: Aug 2007 Location: brighton Drives: C20LET 5dr corsa
| fitment of p2 and boost settings hi chaps, done a search but couldn't find enough info on phase 2...
1. easy enough to fit? whats involved..
2. what boost can i run?
3. fuel pressure?
thank you
__________________ Roll on LET power.... |
30-09-2008, 15:20
#2 | | MIGWeb Moderator
Join Date: May 2003 Location: Nottingham Drives: Mk3 Astra LET
| Re: fitment of p2 and boost settings 1. I think there's a guide on here somewhere.
2. Depends on what other components you have. FMIC, Injectors etc.
3. What injectors do you have?
__________________ MIG Moderator |
30-09-2008, 15:27
#3 | | MIGClub Member
| Re: fitment of p2 and boost settings your always the first one to reply for me... ha thanks mate!
i got a fairly big front mount (2.5" pipework), standard injectors, walbro pump, cossie 2wd FPR, cossie -31 actuator. |
30-09-2008, 15:51
#4 | | MIGWeb Moderator
| Re: fitment of p2 and boost settings Right standard injectors need a fair amount of pressure. Do you have a gauge and also do you have a wideband kit? Without knowing the a/f ratio I wouldnt want to push P2 spec's on standard injectors.
I'm not 100% sure but I think you want 4.5Bar on standard injectors. Please confirm this before you tweak the boost
Its only really your injectors that let you done. Everything else is fine for P2  |
30-09-2008, 16:13
#5 | | MIGClub Member
Join Date: Nov 2007 Location: southend Drives: astra gsi turbo mk3
| Re: fitment of p2 and boost settings Im pritty sure standard injectors on phase 2 is 3.5 bar |
30-09-2008, 16:22
#6 | | MIGWeb User
Join Date: Mar 2002 Location: suffolk Drives: Corsa Tbo n Prelude
| Re: fitment of p2 and boost settings i was also told 3.5 bar on yellows but to be honest every engine is different and getting it set up on the road with a wideband or on a rolling road would be best.
__________________ Bring back the power of LET |
30-09-2008, 16:44
#7 | | MIGWeb User
| Re: fitment of p2 and boost settings 3.5bar for phase 2. I have some saab reds for £40 delivered if you want them? Really good for phase 2 especially if you have adjustable reg. Standard injectors will be getting close to maximum flow on phase 2. |
30-09-2008, 16:55
#8 | | MIGClub Member
| Re: fitment of p2 and boost settings What do saab reds run on evo 5 |
30-09-2008, 17:45
#9 | | MIGWeb User
| Re: fitment of p2 and boost settings £40 is cheap buy em. |
30-09-2008, 17:51
#10 | | MIGClub Member
| Re: fitment of p2 and boost settings Yeh i no thats cheap lol ive already got some.
Whats the bar they run at then? |
30-09-2008, 18:02
#11 | | MIGClub Member
| Re: fitment of p2 and boost settings no money money till next week
whats the max boost i should run then? i have a gauge to check fuel  |
30-09-2008, 18:02
#12 | | MIGWeb User
| Re: fitment of p2 and boost settings i thought it was 2.8, but im gonna work it out for myself when i do mine. id go for 3 to be safe |
30-09-2008, 18:30
#13 | | MIGClub Member
Join Date: Nov 2005 Location: doncaster Drives: corsa xe, corsa let
| Re: fitment of p2 and boost settings Quote:
ph2 chips run 13psi and 19psi overboost and set your FPR to 3.5bar with the vac pipe disconected |
30-09-2008, 18:33
#14 | | MIGClub Member
| Re: fitment of p2 and boost settings This confuses me when people say disconnect the vacum what is this and is it crucial |
30-09-2008, 18:36
#15 | | MIGClub Member
| Re: fitment of p2 and boost settings they mean take vacuum off when checking pressure as it gives the true reading because when the vacuum's on it drops.
13psi held? i have an mbc as well.
whats the limit before boost cut? |
30-09-2008, 18:43
#16 | | MIGClub Member
Originally Posted by dearing5 they mean take vacuum off when checking pressure as it gives the true reading because when the vacuum's on it drops.
whats the limit before boost cut? | not to sure about the boost cut but ive read people running 16-17 psi with no problems. |
30-09-2008, 18:57
#17 | | MIGClub Member
| Re: fitment of p2 and boost settings I use to run 15-16psi on phase 2 |
30-09-2008, 19:13
#18 | | MIGClub Member
| Re: fitment of p2 and boost settings ok cool, im only getting chips to see if its boost cut im getting, which im sure it is. but least once i got them i got them  more fun either way lol.
well i'll set boost at 15psi or so and go from there and just see whats what.
will it still boost cut? if too high? im only looking for 1bar anyway will be quick enough. |
30-09-2008, 19:18
#19 | | MIGWeb Moderator
| Re: fitment of p2 and boost settings You wont get boost cut with the adjustable boost controller unless you plumb it in with the amal valve.
Better to set it to say 14PSI, get the fueling right on the wideband and forget what pressure it should be. The wideband will be far more accurate.
Don't personally like Saab reds on P2/Evo5 as they never ran right on mine. Astra VXR injectors overfuel a little but the ride is far better. |
30-09-2008, 19:20
#20 | | MIGClub Member
| Re: fitment of p2 and boost settings if your only looking for 1bar dont bother with the MBC as your only 1psi away with the amal valve plumed in. have you got another turbo now as i thourt i read your penny valve was cracked |
30-09-2008, 19:25
#21 | | MIGWeb Moderator
Originally Posted by zx7r if your only looking for 1bar dont bother with the MBC as your only 1psi away with the amal valve plumed in. have you got another turbo now as i thourt i read your penny valve was cracked | MBC is still worth having. Just depends on what kind of power delivery you're looking for.
With the MBC set to 14PSI it will climb slightly quicker as the waste gate wont open until 14PSI is met. With the amal valve a small amount of boost is lost throughout the rev range as the valve pulses to regulate boost pressure.
You also get overboost with the Amal valve but some people just like to hit a figure and hold it. |
30-09-2008, 19:50
#22 | | MIGClub Member
Originally Posted by Orange Peel You wont get boost cut with the adjustable boost controller unless you plumb it in with the amal valve.
Don't personally like Saab reds on P2/Evo5 as they never ran right on mine. Astra VXR injectors overfuel a little but the ride is far better. | really? atm mine wont boost over .5bar it just cuts out and kangeroo's... i thought it was boost cut!?!?!
1psi away from 1bar, on standard chips? mine hates anything near that figure. how much of a boost leak can cause problems? |
30-09-2008, 20:36
#23 | | MIGWeb Moderator
| Re: fitment of p2 and boost settings You've not fitted the chips yet have you? Standard boost cut is just under a bar (11PSI IIRC) so you may have another problem. Boost cut doesn't make the car kangeroo either so it could be a missfire due to the plug gap being wrong, not enough fuel, bad leads etc.
Mine used to kangeroo at 10PSI. Turned out to be dodgy HT leads. Changed them and it works fine upto 22PSI which is the Evo5 overboost limit.
Its not boost leak as such its how the wastegate works with the amal valve. Completely normal. |
01-10-2008, 07:14
#24 | | MIGClub Member
| Re: fitment of p2 and boost settings it is taking a long time to spool up though, when should i be on full boost? going to look at waste gate. |
01-10-2008, 07:48
#25 | | MIGWeb Moderator
| Re: fitment of p2 and boost settings Mines quite late too. It starts to make pressure around 3K then comes on full boost very quickly at 4.5K |
Members: 42,530
Threads: 308,061
Top Poster: LEE69 (42,902) | | Welcome to our newest member, DENTYSXI | | » Join MIGClub Today | Join online
now!
of being a MIGClub Member.
