When i start the car from cold there is a squeak come rome the engine bay sounds bit like a slipping belt.
But when i depress the clutch peddle the noise tends to go away.
Any ideas i have never know a clutch to make that noise when it is on its way out.
I thought it may be a slipping belt, but when you push the clutch inn it changes the noise it makes.
If it was a belt would it realy be affected by using the clutch.
Normaly if it is the gearbox and it goes away with the clutch pussed in it is the input shaft. That would be noisy all the time though, not just first thing.
I suggested the belts cos when your driving and you put your foot on the clutch the revs drop to a speed where the belts don't slip anymore so they stop squeeking, of course from hear I've no idea what the sound is actually like.
Where about in Chester do you live? I used to live near there and actually miss it, its the nicest place/town I've lived near and wouldn't mind moving back.
Mine used to squeek allot, i know for sure it wasnt the belts too loose or knackered cause i replaced and tightened them. My money is on either the altenator shaft bushes, or the power steering pump shaft.
Ive noticed mine hasnt squeeked for ages, and i ditched power steering a while ago, coincidence ? maybe.
Just wondered if you have tried checking for a clutch problem.
Put the hand brake on and try to pull away in 1st, if the engine revvs increase but you go nowhere and there is now mothine, etc then the clutch may actually be at fault. If it stalls, or the front of the car lifts its okay.
Just a quick thought, as i'm bored!!
72.7K members
