alternator faults, astra van 2003 1.7TD
Results 1 to 6 of 6
Thread: alternator faults, astra van 2003 1.7TD
    Jul 2008
    hi everyone
    just signed up to the site, got an astra van 2003 1.7TD and i think the alternator has packed in, not charging the battery up any more.
    are they a straight easy swap?
    plan on just buying one off ebay and fitting it
    does it need to come off an 03 1.7TD van or are they are part that is used in many vauxhalls
    cheers
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    Re: alternator faults, astra van 2003 1.7TD
    Check the battery light hasn't blown first. This needs to work to 'jump' the alternator.
    They're there, in their room.
    Jul 2008
    battery light works, charged up battery and car starts and runs (with the battery light on all the time)
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    Ah. Knackered then!
    Jul 2008
    bugger, anyone with a bit of advice about buying and fitting one?
    are all the alternators the same for the mk4 astra van 1.7TD
    can i just simply unbolt the old and bolt in the new, job sorted?
    cheers
    Apr 2011
    My battery light has blown, I have taken the clocks out and took the black cover off the back. My van is a 2000 Astra mk4 1.7 dti. How do I change it?
