Go Back   MIG Performance Vauxhalls > MIG Technical > Engines and Transmission
Engines and Transmission Technical forums for the discussion of all engine, transmission, turbo, ECUs, fuel systems and the like.
Old 13-07-2008, 11:46   #1
Drives: corsa turbo, skyline
c20xe hesitation and no power on/off
just put a c20xe dispac engine in a corsa b, its been fine for the first 10-15 miles, then on a trip out today it started loosing power and bogging down, pulled over, and it ticks over fine, rev it up and it misses and pops abit, but..... if you turn the car off and re start it you can drive fine for 30 seconds and it does it again, or.... if you thrash it it wont do it at all, its just under normal driving?
jamie gsi16v is offline   Reply With Quote
Old 13-07-2008, 14:32   #2
Banned
Drives: Astra 3 P2 LET
Re: c20xe hesitation and no power on/off
Suspect dispack? Cold be cracked.
Most cars i've had with dodgy coils/packs have worked fine full chat, but really bad at low RPM & normal driving.
Terry81 is offline   Reply With Quote
Old 14-07-2008, 16:17   #3
ok been out in the car today and its fine for the first 2-3 miles then when upto temperature it does it again, revs between 1-2k and has no power and slowely dies under acceleration, turn the car off and on and its fine for the first 30seconds.
Old 07-10-2008, 21:06   #4
Drives: astra gsi c20let ph2
did you ever get this fixed???
GSITURBOASTRA is offline   Reply With Quote
Old 07-10-2008, 21:21   #5
yeh the wires had broken to the coolent temp sensor.
Members: 42,530
Threads: 308,061
Top Poster: LEE69 (42,902)
Welcome to our newest member, DENTYSXI
