how do you plumb in the 2s water injection system
Results 1 to 5 of 5
Thread: how do you plumb in the 2s water injection system
    Mar 2002
    anyone know how to set up the 2s water injection system does the mf2 be i=n the car where does the pressure switch go the manifold pressure switch also has a type of realy with 3 pins which wires connect to this and to which pin please help im a little lost.
    Nov 2000
    Woking, Surrey
    GTE 16v Turbo
    Re: how do you plumb in the 2s water injection system
    Originally posted by tabs
    im a little lost.
    As am I reading that
    Can you write it out again and make it a bit clearer?
    Contemplating lots of things
    Astra GTE Turbo - Link Now Working
    Mar 2002
    Thread Starter
    sorry jus read it myself.
    1 where does the vacum pressure switch go
    2 the nannifold pressure switch has 2 contacts on it but not labellled so am i right in saying it doesnt matter which wire conmnects to which spade on the pressure switch
    3
  5. Remove Advertisements
    Sep 2000
    Near Stirling
    10s Evo VI,12s Astra
    Check on the ERL website.
    Loads of useful info hidden away on there.
  7. #5
    RDS
    RDS is offline
    Jun 2001
    Plymouth
    Veccy 3.0 24v Diesel
    Tabs the pressure switch doesnt matter which way round you put the wires!
    The pressure switch goes into one of the tubes behind the inlet manifold which sends vacuum/boost pressure to the ECU etc.
    Sir, please step away from the car
