Oil catch tank / breather mod ?
Results 1 to 2 of 2
Thread: Oil catch tank / breather mod ?
    Jul 2002
    Question Oil catch tank / breather mod ?
    I have a Westfield fitted with a c20xe engine that has a fabricated oil catch tank. It has two pipes (1 big - 1 small) that go from one side of the cam cover to the catch tank.
    Should the pipe (v.large) on the other side go to the tank when I do the breather mod ? At the moment It goes from the cover the metal pipe (crankcase ?). I have read that the small pipe gets blocked off ?
    The engine is running on twin 45's so I believe I should do the mod that removes all but the small square, is this right ?
    Northeast Kent
    if you mean that big pipe from next to the dipstick, leave that connecting to the cam cover. basically leave everything as it is but do the breather mod.
