help needed x18xev imobilizer wiring problem
Results 1 to 9 of 9
Thread: help needed x18xev imobilizer wiring problem
    Jun 2002
    gateshead
    cavalier turbo
    any help gratefull received i am stuck wiring a vectra 1998 vectra 18xev up in a nova.i cant find any diagrams on autodata.i have the immobilizer connector in front of me no pins are as follows
    1 brown / purple
    2 brown / blue
    3 unused
    4 brown/white
    5 black switched +
    6 red/blue immobiliser signal
    7 blue/black
    8 brown/white
    9 red 12v
    http://i22.photobucket.com/albums/b3...c/DSC00018.jpg
    i have the black to switched live,the red to constant 12v,and the blue/ red to ecu directly onto the x7 plug(pin 10 blue/black)i have traced through to ecu pin 5 immobiliser.the fuel pump is wired.The engine harness has a big fused live which is to battery for now the earth is connected ive got no spark.i have all the matching immobilzer bits.is there anything else need conecting to get this lump to run
    http://i22.photobucket.com/albums/b3...c/DSC00019.jpg
    the x7 i have following pins
    1 red/blue
    2 black
    3 brown/white
    4 brown/yellow
    5 brown/blue
    6 grey
    7 unused
    8 red/blue (thick)
    9 unused
    10 blue/black
    11 blue
    12 unused
    13 green
    14 unused
    15 black/blue
    16 brown/viloted
    17 black
    18 unused
    19 unused
    20 black
    21 black/white
    22 brown/blue
    23 red/blue
    24 black/red
    i can find a pinout for the v6 but not 1.8 hope some one can help i have no spark,hope someone can help dave
    The force of the piston(s) on the crankshaft (through the connecting rod) becomes a rotational force called 'torque',
    Feb 2002
    Co. Kerry, Ireland
    2.0 Nova, Astra Mk3
    Only wires you need to worry about are:
    Red > 12v
    black > ignition live
    brown > earth
    brown/blue > brown/blue - ECU light
    blue/red nearest to the red 12v wire goes to the blue/red in the ECU loom plug
    other blue/red goes to the speed sender on the gearbox.
    And that's it.
    Feb 2002
    Co. Kerry, Ireland
    2.0 Nova, Astra Mk3
    Actually, just realised it's a Vectra loom you have. Immobiliser wire in the big ECU plug is blue/black on the Vectra.
    In your X7:
    Pin 1 red/blue >fuel pump
    Pin 2 black > ignition live
    Pin 5 brown/blue > ECU light
    Pin 10 blue/black > immobiliser
    Pin 11 blue > coolant gauge
    Pin 13 green > rev counter
    Pin 22 brown/grey > secondary air injection relay.
    They're all the ones you need.
    On the Vectras, the brown secondary air injection relay is a part of the car loom, so you'll have to cut the brown relay plug out of the fusebox by passenger side suspension turret and wire it into the Nova loom. I had to do this on a Nova I put a Vectra 1.6 XEL engine into. As far as I can remember, it was only a 12v and ignition live connection on the relay and then join the brown/grey to the brown/grey in the X7 plug. If you don't wire it in, the engine will run fine, but you'll be left with the ECU light blaring at you all the time.
    Jun 2002
    gateshead
    cavalier turbo
    hi thanks i only have1 blue/red in the immobiliser andnow i am beggining to think its a speed sensor and the blue/black is my immob signal.just noticed you edited lol disregard what i just said lol,
    Feb 2002
    Co. Kerry, Ireland
    2.0 Nova, Astra Mk3
    No worries lol. Make sure your immobiliser chip is sitting in the middle of the transponder ring when you go to start it. If you stick it on the outside edge of the casing, it can be hit and miss as to whether the transponder picks up the chip signal or not. Sometimes it'll start fine, others the ECU light will just start flashing at you and nothing.
    Jun 2002
    gateshead
    cavalier turbo
    just been out neigbours not happy lol, still no go you wouldnt happen to no if the pin 7 blue/black on the immobilizer plug is the signal wire and not pin 6 red/blue mate would you my heads battered now.
    Feb 2002
    Co. Kerry, Ireland
    2.0 Nova, Astra Mk3
    Yeah the blue/black is the immobiliser signal wire. The blue/red goes to the speed sender on the gearbox
    Dec 2001
    Chelmsford, Essex,
    1.6LPG, 1.8, 1.9CDTI
    Transponder Blue connector
    Code:
    Pin  	Colour  	Function
    1 	Brown/Red 	Alarm Input (Optional)
    2 	Brown/Blue 	Engine Management Light (Optional)
    4 	Brown 	Ground
    5 	Black 	Ignition
    6 	Blue/Red 	Speed signal from ABS/clocks (Optional on V6)
    7 	Blue/Red 	Speed signal to Engine ECU (Transponder signal)
    8 	Brown/White 	Diagnostic (Optional)
    9 	Red 	12V
    Jun 2002
    gateshead
    cavalier turbo
    thanks mark but mines different doesnt have the x2 blu/red it has blue/black in pin 7 and blue red in pin 6 i am now assuming pin 7 is immob and 6 is speed signal,does speed signal need to be connected for car to run,thanks again dave
