Bleeding a vectra clutch setup
Results 1 to 16 of 16
Thread: Bleeding a vectra clutch setup
    Macclesfield
    www.Retrobike.c
    Just currently trying to bleed up my hydraulic clutch setup to make sure its ok and i have a few questions. I take it the clutch slave should not be movable when the clutch pedal is compressed? ie it should be fully out and solid. I am checking it all with no clutch or engine in the car.
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    yeah, should be solid, vaux reccomend use of a pressure bleeder for their clutch slaves
    SHoNkyOpELs.de
    Aug 2007
    United Kingdom
    Shogun
    Yup, as the man said use the pressure easy bleed system, tried doing it without one at the weekend and it was a waste off time!
    Dont you dare delete the above!
  5. Remove Advertisements
    Mar 2003
    Manchester
    Corsa C / RWD Nova
    These Eezibleed's make the job so much easier - We use these quite a lot at work when struggling to 'get a pedal'
    You may have to modify a cap to fit your fluid reservoiur bottle though
    http://cgi.ebay.co.uk/Eezibleed-Kit-...sid=p1638.m123
    Dave
  7. #5
    Macclesfield
    www.Retrobike.c
    Thread Starter
    Got one of those dave, just used it and its all spot on now. I can bolt it all in place tomorrow, safe in the knowledge i will never have to change another nova clutch cable!
  8. #6
    Rs1
    Rs1 is offline
    Dec 2004
    Newcastle
    Corsa C SRiT & Meriva VXR
    Quote Originally Posted by Rick Draper View Post
    You'll not be so happy when the slave starts leaking
    I didn't think the twin clutch was that heavy tbh, i think the majority of people who have cable probs have them routed incorrectly or have old cables perhaps? The one i have snapped in the past and have seen snapped always go at that little hook.....pedal side
    "THE ROB"
  9. #7
    Awaiting Email Confirmation
    Jun 2002
    ffs don't bleed it off the car, you'll overstroke it and when you fit it, it'll piss everywhere.
  10. #8
    Rs1
    Rs1 is offline
    Dec 2004
    Newcastle
    Quote Originally Posted by tathan View Post
    Good call, i assumed it was in alreadylmao
    "THE ROB"
  11. #9
    Jun 2002
    biggest warranty claim by miles at work is bled off car, overstroked piston, pops the seal out, fit to car, pisses all over clutch.
    we are going to need a new REJECTED stamp soon.
  12. #10
    Oct 2006
    North Wales
    Nova 2.0 16v
    REJECT !
    Better go buy another one mate, or send it to the cwds at QH Colwyn BAY
    Dont worry, loads of people make that mistake.
    "NOVA'S NEED VALVERS"
  13. #11
    Jun 2002
    Don't send it to us, we'll bounce it so hard it'll hit the moon.
  14. #12
    Macclesfield
    www.Retrobike.c
    Thread Starter
    Its in the car not out of it. I am having to set the throw of the pedal to make sure i have it all setup right when the box and clutch goes in.
  15. #13
    Jun 2002
    Yeah, but if it's not pressing against the clutch pressure, it'll overstroke.
  16. #14
    Jul 2003
    trowbridge wiltshire
    mk2 cav turbo
    what i do is get someone to sit in the car and push the pedal down, hold it down as i undo very slightly the bleed nipple, then tighten befor letting the pedal back up. reapat 4-5 times and the pedal is ok. always works for me
  17. #15
    Macclesfield
    www.Retrobike.c
    Thread Starter
    Re: Bleeding a vectra clutch setup
    ****ing piece of **** is still not working right now its all built up. Tried the eezibleed kit and i am so hacked off with it all.
    Back in the scene
  18. #16
    Oct 2000
    Sunny Milton Keynes
    Bmw 3 series
    Quote Originally Posted by therich View Post
    Yes, but eazibleed is a one man operation.
