Engine IDENT codes needed
Results 1 to 1 of 1
Thread: Engine IDENT codes needed
    Apr 2002
    Nr oxford, in flat,
    Astra MK4 XSI
    Unhappy Engine wiring IDENT codes needed
    Could someone possibly get me the IDENT codes (located on the wiring looms) for the engine wiring harness (ident at each end of the loom) and the starter / alternator loom (ident located by the suspension turret main plug).
    For the Astra MK3 2.0 16v, REDTOP GSI with the CAT!!!! and o2 sensor.
    The IDENT codes are two digits, usually numbers.
    Many thanks for any one that has this car and can help
