hi people, need to remove my drive shafts from my f20 gear box. whats the best way of doing it?
theres like slack in the cv joint, grab the driveshaft, push it towards the gearbox and pull it back as far as it will go, do this a couple of times and the lot should pop out.
If you dont want the G/box oil to spill out - undo ball joint, remove hub nut, unclip the inner gator (G/box end), remove shaft from G/box, pullout cv joint.
hope this helps
the gear box oil has been drained. its just the gearbox & shafts. ive removed the hubs etc
Yeh just give it a pull works 90% of the time.
Other than that stick a nice strong starp pry bar in the slight gap betweet the shart and the box.
Paul
Just yank the shaft.
if tugging the shafts dosent work, drop off the the diff cover plate on the bottom of the box, you will see the diff, rotate the diff/sfats untill you can see the end of the cv in the diff, jab a screwdriver inbetween the diff and the end of cv and give it a tap with a hammer and it will pop straight out, this is by far the eaiest way, but it is the messisest due to having to drop the box oil out.
As Jamie said.
Also if you can get the 1st out, you can knock the 2nd one back through the centre.
