Hi
Bought a astra mk4 gearlever to put into the cav. Is it just a case of swapping the levers over or do you need to change the cage as well.
Hi
just swap the levers, theres a pin at the bottom which just unclips and pulls out.
ill 2nd that 2 min job very easy.
Cheers guys
