corsa gsi c16xe fault codes
Results 1 to 5 of 5
Thread: corsa gsi c16xe fault codes
    May 2007
    Ffarmers
    Swift gti
    My corsa gsi emlm light is coming on after about a mile of driving. I have flashed the codes out and they have come up as the following: 24, 28, 93. Can anybody help.
    Before this i changed the fuel pump relay as it was corroded. When i started the car the eml light wasnt on until i drove it. Also the speedo isnt working is there a pickup on the gearbox for this? any help would great. Thanks.
    Nov 2000
    North Ayrshire
    06 Fabia vRS
    the speedo not working is causing code 24 to come up. Snapped speedo cable?
    May 2007
    Ffarmers
    Swift gti
    where does the speedo cable mount on the gearbox?
    Wolverhampton
    corsa gsi
    right at the top of the gearbox, bit tricky to get to, probably have to take out battery, and depending on what inlet you have i.e standard or tbs/matnzel could be hard to get to, will also probably have to take out the expansion bottle, as its directly under there
    16.1s 1/4 mile with a c16xe - mantzel style inlet, 4-1 exhuast, de-cat straight through and chipped, not that bad a time.14.7s 1/4 mile honda civic 1992 sir 1.6 - decat and induction kit, now thats a good time. Time to go jap i think!
    Wolverhampton
    corsa gsi
    28 is your fuel pump relay contacts, so this code might still be registered in the ECU from before you changed it, so disconnect the battery for about half an hour to clear the codes, and see if it still comes up, and code 93 Quad drive module (in ECU) havent a clue what this means, might need a new ecu
