Engine Not Starting
Results 1 to 17 of 17
Thread: Engine Not Starting
    Dec 2007
    Forest Gate, London
    Astra mk3/mk4
    Engine Not Starting
    Hi
    Ive tried the ovibous, i left car battery on charge. but the battery is fine. Changed spark plugs. Still didnt work. Then i cleaned the innjector out and idling spring. it still didnt start. then i new it wasnt a fuel problem as i can see the fuel coming out of the injector. then i opened the distrubutor cap and cleaned it out. and still does not work. PLEASE HELP ME AS I NEED TO GO SOMEWHERE TOMORROW
    Apr 2005
    near glasgow
    nova 2.0t 8v soon :)
    please help us you havnt said what engine
    Dec 2007
    Forest Gate, London
    Astra mk3/mk4
    Hi
    Sorry here is the data
    Engine size: 1.4i
    Engine model: C14NZ
    Year: N reg
    Thanks
    Apr 2005
    near glasgow
    you gettn a spark?
    Dec 2007
    Forest Gate, London
    Astra mk3/mk4
    how can i check itt correctly as i have been told to open the spark plug and then lean it against any netal component and then connect and give it a start. Please tell me the correct way
    Sep 2004
    Nottingham M1 J26
    911. Loves: Dirty sluts.
    Pull an HT lead off the plug and leave it near a metal part of the engine. Crank the engine over and you should see a spark jumping the gap.
    Next, crank the engine over for a few seconds then take the plugs out and sniff for fuel, you should smell it in the cylinders.
    Is this an engine swap, did the car run previously? What's the history with this?
    Dec 2007
    Forest Gate, London
    Astra mk3/mk4
    Hi
    This car has given me nothing but trouble. When i brought it 6 years ago the ignition coil went. Then the head gasket and then so many other things. It was working perfectly before.
    Sep 2004
    Nottingham M1 J26
    OK well check for fuel and a spark then come back!
    Dec 2007
    Forest Gate, London
    Astra mk3/mk4
    Hi
    Checked for spark and there is nothing at all. I followed your instructions. What shall i do as none of the leads are letting a spark through.
    Sep 2004
    Nottingham M1 J26
    Take the king lead off the coil, and see if the coil is producing a spark (you may have to use a socket extension or something to give the spark an earth)
    If there is a spark here, then your distributor is faulty
    If there is not a spark here, then you need to do more checks.
    Can you smell fuel if you remove the spark plugs?
    Dec 2007
    Forest Gate, London
    Astra mk3/mk4
    Yes i can smell fuel at spark plug
    Sep 2004
    Nottingham M1 J26
    Okay check for a spark at the coil. You could also use a multimeter to check the coil has power.
    Dec 2007
    Forest Gate, London
    Astra mk3/mk4
    i have a standard mulitmeter for use on standard house electricity. Will this be okay. And what mode shall i put it on?
    Gagged
    Feb 2005
    Boro
    Corsa Sport C20XE
    yea that will be fine, put it on DC 200 Volts if it has that setting.
    Dec 2007
    Forest Gate, London
    Astra mk3/mk4
    Quote Originally Posted by Nemesis View Post
    Hi
    I checked for a spark but there is nothing.
    Gagged
    Feb 2005
    Boro
    Corsa Sport C20XE
    Id change the coil pack with another one, also make sure the power connector that powers the coil pack is correctly plugged in. If so and still no spark id check the crank sensor.
    Dec 2007
    Forest Gate, London
    Astra mk3/mk4
    crank sensor???
  1. 10-02-2008, 15:42
  2. 02-02-2008, 19:56
