Wayne - that's the first thing i tried lmao i gave them a nice tap with a rubber mallet and they cliped (opened!) although i didn't put a socket over the cap piece so i try that!
Chip - if that is right then cool, but i wondered if the added restrictions of the turbo and oil cooler would reduce flow rate?!?!? and i can definately spring to a new set of bearings!
Jim - good info on the oil pump! thanks for that. as for the crank, i don't intend for much more than a normal 6500 - 7000 rpm (this engine never really reved hard anyway!) but the turbo will add on a load more torque which may have the same outcome. are the cranks out of the 'new' 1.4 fabias any different (i thought about adding 1.4 fabia crank and rods to up the cc!). as for the pistons they are the dished type. the compression ratio (as i understand it) is fairly low on these (8 - 9??). i thought about doing the easy cop-out and adding a thin spacer or something of that sort, or i may just leave it and see where we are at!
are the genuine bearing shells the ones to have? what else ya got for an estelle?![]()
on a different matter jim..... wheels.... 113pcd means not many wheel options... i was wondering about having the hubs re-machined to 100 pcd? possible? infact any gen about then from anyone?![]()
but tbh all the bug wheels i have seen look to like bug wheels and i don't think they will work with the look/style i want!
