went out in my nova for the first time since puttin an xe in went ok then lost revs an cut out an wouldnt start there are no falut codes comin up an it started up first time 2 days later.anyone have any ideas
its gettin fuel couldnt check the spark coz it was pitch black couldnt see what i was doin will try again tomoz.as for speedo its a digi dash out of gte an was workin mate.why what would it do if it wasnt??
Sounds very much like the coil amp. They give you trouble when they warm up. They're 140 quid new for the little thing from Vauxhall, so just get a coil from a scrap car for 20 quid. They're the little black box under the coil.
I think there's a way of checking by seeing the voltage across each of the + - points on the coil, I think it doesn't 'switch' properly between the two when the amp is knackered, but a start with that, I reckon that's what it is.
