hi ppl, i've just finished installing and wiring in my gauges into my 53 plate gsi turbo and am after some help as to where the factory oil pressure switch is located.
my plan is to remove this switch, and fit a short braided hose with a tee peice on the end into the block, then fit the factory switch one side and the sender for the gauge the other side of the tee.
does anyone on here have any advice/suggestions on this??
any help would be greatly appreciated.
thanks matt
thanks matt
